Gauge Cluster Question
Old Aug 24, 2008 | 10:55 PM
lb87ralliart's Avatar
Question Gauge Cluster Question
I've seen a couple of gauge clusters for the evo (ya know with the 9000rpm, 160mph layout) on ebay and that ralliart japan site. Would i be able to hook it up to my 04 ralliart? is it even possible? or not, because the evos rpm gauge is where the ralliart arts spedo gauge is?
i'm just curious if its possible
Old Aug 24, 2008 | 11:31 PM
uprockmankey's Avatar
It's a plug-n-play I believe but it'll reset your mileage I think. Search for more details, this is very well covered already.
Old Aug 25, 2008 | 04:27 PM
k3lv's Avatar
Its possible, I use a JDM Evo 7 cluster. Everything will work fine, the computer will recognize which one is rpm and which one is speedo. Few icons might be different(at least on the JDM one) but thats about it!
Old Aug 25, 2008 | 05:34 PM
This Guy's Avatar
isnt the redline at 7000rpms instead of 6500rpms on the cluster?
aint it also bad if your racing and let the rpms go to 7000rpms?
Old Aug 25, 2008 | 08:38 PM
Thomar's Avatar
rpm limiter
Old Aug 26, 2008 | 05:46 PM
k3lv's Avatar
yeah it is the redline is diffreent but once you know the car you never stare at the gauge anyways
Old Aug 26, 2008 | 06:18 PM
bcollinstex's Avatar
The redline on the gauge is just a readout. The ECU controls the actual redline of your car (rev limiter).
Also, the mileage listed is built into the gauge cluster. So whatever mileage the car had on it from the cluster you bought, is what your car will now read.
I believe you can send this off to mitsu to have it changed, though I'm not sure of that cause I don't know anybody who has done this.
Old Aug 26, 2008 | 07:42 PM
Realistic's Avatar
i've tried numerous times to have it changed to the correct milage, without success... if anyone has a solution, pm me
Old Aug 26, 2008 | 10:30 PM
k3lv's Avatar
Can't help you with the mileage issue, I got a gauge cluster that reads KM's and was only off by 1000 in total mileage so I'll always remember what I'm really at
Old Aug 27, 2008 | 08:00 AM
This Guy's Avatar
so how does the rev limiter work? the ecu wont let the engine rpms go past 6500rpms?
Old Aug 27, 2008 | 08:05 AM
I'm not positive how they work on our engines, but commonly rev limiters will cut ignition and or fuel.
Old Aug 29, 2008 | 08:13 AM
This Guy's Avatar
oh yeah i forgot to ask this question, does the evo cluster light up brighter than our stock clusters? my friend was riding wit me one night and ask why i have my gauges dim and i told him thats the brightest my cluster lights up
Old Aug 29, 2008 | 05:10 PM
GearDownSon's Avatar
Yea i have an evo cluster an its a lit dimmer than stock imo
Old Aug 29, 2008 | 10:19 PM
k3lv's Avatar
Take your lights from your stock gauge cluster and put it in the Evo. Mine was so dim I couldn't read it so I shoved those big red condomed bulbs from the stock cluster to the evo cluster and wow it lights up real nice with the red numbers on the jdm evo cluster.
Old Aug 30, 2008 | 08:46 AM
otter's Avatar
EvoM Administrator
Evo cluster isn't brighter than ours at night. Also, the Evo cluster is really hard to read in the daylight with sunglasses on. Dark red letters on a black background aren't easy to see. If you want the stock cluster brighter, switch the bulbs to LEDs.
