New accomplishment Part2
Old Nov 7, 2008 | 09:17 PM
SSP-Ralliart's Avatar
This thread will be dedicated to the build of NA power into the 11's. As everyone has read in the first thread i am going turbo. I am not turning back from what i said in the last thread but I am going to give it one last try and see if i can get into the 11's. Plus RRM has a new product they are going to have me try which will help get me that much closer to my goal NA. I will take some pics of my progress which will including Before and after engine bay, tear down of the stock RA engine (completely) and the rebuild with all the goodies which i am making. I will try and answer any questions ya'll may have about NA power building to the best of my ability. Also within this thread i will add my turbo progress when i start the fabrication and building. Thank you for you time and also your support.
Old Nov 7, 2008 | 10:14 PM
Christoforo's Avatar
Can't wait to see how it comes along! Good luck man.
Old Nov 7, 2008 | 11:19 PM
samj601's Avatar
so whats the new part?
Old Nov 8, 2008 | 03:27 AM
joeyj's Avatar
+3
Old Nov 8, 2008 | 10:08 AM
Ralli04's Avatar
Originally Posted by joeyj
+3
+10
Old Nov 8, 2008 | 10:52 AM
Pin2Win's Avatar
+199
Old Nov 8, 2008 | 11:58 AM
snakoil's Avatar
+∞ (meaning + infinite)
Old Nov 8, 2008 | 01:01 PM
heartagram88's Avatar
good luck man...11 seconds with a car that only does 15s is very impressive, faster than a stock evo by alittle bit...since your NA im pretty sure youve got alot of torque right...and im curious to see what the new part is coming out from RRM, is it involve the turbo set up...
Old Nov 8, 2008 | 01:12 PM
Only for NA cars.
Old Nov 8, 2008 | 06:01 PM
samj601's Avatar
u serious? stock evo's do not run anything near that
Old Nov 10, 2008 | 08:37 PM
Cj98's Avatar
Hoping to see pics!
Old Nov 10, 2008 | 09:01 PM
Alittle update from here at SSP. I am in the process of making a Camshaft for the mivec 4G69 engine which will compete against the Toda Vtec Killer Cams. Plus getting together Valve train components that can handle the amount of lift. This camshaft will still utilize the Mivec feature. This camshaft will have a very lumpy idle. Also I am in the process of making 12.5:1 compression pistons. If those work out good then i will go to 14:1 compression pistons. I am also making a different crank shaft and rods to handle the amount of stress including upgrading the bottem end of the 4G69. I will take pictures and update as i move along. Thank you for following along and next year I will try to make the 11's and possibly 10's before i go turbo. I will also keep ya'll updated on my Ra monster turbo build.
Old Nov 10, 2008 | 09:08 PM
SpunEvoIX's Avatar
you all should do a lancer and honda merge then for NA
Old Nov 10, 2008 | 09:19 PM
why merge. I am helping the Lancer community since there are no fast evos in the chico area.
Old Nov 11, 2008 | 05:52 AM
Ralliart_on_LSD's Avatar
what the new part!
