need help
Old Dec 11, 2008 | 07:42 AM
stitch_sack's Avatar
need help
was driving home from work today and my car just died. Pulled over and tried to start it up again and would die instantly. After a couple miniutes it would start and idle but when I would press the gas it would sputter and die. A miniute later I was able to get in motion and get moving at about 10 mph. Then all of the sudden everything was working fine and i got about half a mile and there was nothing again. Got the car home in first gear with the gas to the floor and going 5 mph, if I let off of the gas at all from the floor it would die. Anyone have a clue???
Old Dec 11, 2008 | 08:13 AM
otter's Avatar
EvoM Administrator
Cel?
Old Dec 11, 2008 | 08:19 AM
condi's Avatar
hmm... may be some sparkplug problem but then again could be many things : /
Old Dec 11, 2008 | 09:19 AM
yea there is a cel i am going to call my buddy and borrow his diagnostics tool but he is asleep right now
Old Dec 11, 2008 | 01:51 PM
KreepaEvoX's Avatar
Clean your Maf with electronics cleaner, reset the ECU. If it keeps up check what cel code is giving.
Old Dec 11, 2008 | 09:30 PM
ok i just plugged the battery back in and it seems to working fine the cel is gone but i havent driven it yet becuase its cold and i dont want to push it in the cold if it dies. thanks for the help!!
Old Dec 12, 2008 | 10:39 AM
otter's Avatar
EvoM Administrator
Right, but see, now you reset the code, and you have no idea what went wrong or if it'll happen again.
I have no idea why people recommend it, but you should NEVER reset a CEL until you actually know what it is.
Old Dec 12, 2008 | 01:57 PM
KreepaEvoX's Avatar
That's pretty much common sense Otter. But, at the same time, U also know that Mitsu vehicles give bogus codes all the time, and most times that damned code u pull is the result and not the cause of the problem. I should know why I say it
Old Dec 12, 2008 | 02:55 PM
otter's Avatar
EvoM Administrator
I've never had my car throw a bogus code. Every code it's thrown has been thrown for a reason.
Old Dec 14, 2008 | 07:10 AM
KreepaEvoX's Avatar
Oh, mine does it allllll the time. Mitsu has gone to hell with their new ECUs. I remember that I could run my Mirage without TPS when it broke, without flow meter without stalling, that one could easily trick the ECU into not rev-limiting, to get close to 10 hp by just moving a damn sensor
You dont even know how many times I pulled random misfire, and bank 2 lean codes, EGR flow obstructions, TPS failures, and dont even get me started on the maf... The problem is, I've never replaced none of those sensors or change anything, and it purrs like a kitty still, well like a kitty with bracers cuz I need to adjust my valvetrain, lol
Old Jan 19, 2009 | 09:58 PM
well i replaced the mass and it hasnt done it yet but now sometimes when I push the clutch all the way in when im breaking it drops below 500 rpm and kills the engine and have to pop the clutch to get it running again. Doesnt happen all the time but it happens. No cel.
Old Jan 19, 2009 | 10:59 PM
GearDownSon's Avatar
+1
Sounds like its going into limp mode..
Old Jan 21, 2009 | 09:21 PM
ok happened again on my way to work. DTC P0638: Throttle Actuator Control Motor Circuit Range/Performance is the code. could my piggy be the cause of this?
Old Jan 24, 2009 | 08:49 PM
Cj98's Avatar
Make sure all clamps are on tight. I had a simple thing like that scare the hell out of me
Old Jan 25, 2009 | 05:46 AM
I dont know if its that simple, when it happens I pull to the side of the road and turn everything off and wait about 5 minutes and it will start up and be running fine again for a short period of time. Its really frustrating
