Grounding kit REVIEW!
Old Jan 29, 2009 | 12:57 PM
  #31
BiCiRA's Avatar
^^^ the first one comes from the place near the cam position sensor and the second one goes to the place near the coils!!!!
Old Jun 11, 2009 | 12:27 AM
  #32
zenergi's Avatar
Battery - boot
as to the question with the battery boot install in regards to the earthing.
It's best to ground the negative terminal of the battery to both the chassis close to the battery install as well as running a o gauge ground cable back to the stock ground point.
Grounding anything in the boot (other than the main ground point) will make no difference.
Old Jul 25, 2009 | 08:36 PM
  #33
Corton520's Avatar
i have a question about this cuz i keep seeing gauges are we talking about size or actual gauges in the car? i read this thread and im still cofused about this whole entire wiring job however i do understand the whole volts and amps thing cuz i took electronics my junior year anyone wanna enlighten me? pm or on here for others
thanks
Old Jul 25, 2009 | 09:06 PM
  #34
hackish's Avatar
Google AWG for a description. If you plan to do this mod the less aestetic but cheapest and best quality solution is to use welding ground cable. Stereo cable unfortunately is not good for the temps in the engine bay. It catches fire when it melts and falls on hot engine parts. Ask me how I know.
Also, if you do this mod you should first research what a ground loop is. In time the factory grounds do degrade so in that case this is a valid mod to do.
If you like rewiring stuff then rewire your headlights with some 8gauge. That's definitely worthwhile!
-Michael
Old Jul 25, 2009 | 09:08 PM
  #35
Corton520's Avatar
haha wat difference would that make on the headlights?
Old Jul 25, 2009 | 09:10 PM
  #36
Sharkbite2000's Avatar
Holly ground batman!!!
Old Jul 25, 2009 | 09:11 PM
  #37
Corton520's Avatar
hey cut me some slack im only 17 and just got my 04 ra back in january im learning hahaha
Old Jul 26, 2009 | 04:54 AM
  #38
robyn402's Avatar
i hope u upgraded the wire from your alternator - battery.... battery - engine.... and battery - fuse box lines as well
4g94T
Oct 4, 2015 12:05 PM
4g94T
Sep 24, 2015 09:40 AM
TKEVO
Feb 24, 2011 08:53 AM
TKEVO
Jun 23, 2010 03:25 PM
alexlewand
Nov 16, 2008 05:01 PM
