steering column
Old Jul 5, 2009 | 11:19 PM
Realistic's Avatar
steering column
hey guys...
a friend of mine has swapped his 06 ralliart steering column out for an evo9 steering column.. along with the accessories that go with it..
my question is.. would the 03 evo 8 steering column work with the 06 ra?
thx guys!
Old Jul 6, 2009 | 03:57 AM
Joyrider's Avatar
What's the EVO's steering wheel ratio ? What's the biggest advantage of this mod ?
Old Jul 6, 2009 | 05:20 AM
Realistic's Avatar
Something compatible with the 06 ra. Right now we have no options for hubs or wheels as it is.
Old Jul 6, 2009 | 05:43 AM
rdc's Avatar
rdc
Yes they will work. The only benefit of it is the ability to put on an Evo Steering wheel. since you´re not touching the rack and pinion setup, you won´t be affecting the steering ratio of the car.
Old Jul 6, 2009 | 05:19 PM
Realistic's Avatar
Now that we're on the topic, how do we go about getting a higher ratio steering column/wheel? Where would I start? At the steering column? Or is it in the hub/wheel?
Old Jul 6, 2009 | 05:36 PM
otter's Avatar
EvoM Administrator
You'd have to install the Evo steering rack. PITA job.
Old Jul 6, 2009 | 05:37 PM
Realistic's Avatar
Thanks otter... That's for the ratio question, i'll assume... What does PITA stand for?
Old Jul 6, 2009 | 05:52 PM
Christoforo's Avatar
Pain in the ***
Old Jul 7, 2009 | 11:43 AM
Joyrider's Avatar
As I can see, EVO have a really bad steering ratio. Don't know if it's better or worse then ours but if you saw Tog Gears, lock to lock on the EVO (8-9) isn't impressive.
Old Jul 11, 2009 | 01:04 AM
robyn402's Avatar
yea only advantage to swapping the shafts is putting the evo wheel on, looks way better... one of the best things i ever did for my ralliart
Old Jul 11, 2009 | 08:12 AM
otter's Avatar
EvoM Administrator
Our car's lock to lock is 3 turns and I believe the Evo is only 2.
