question about motor mount interchangeability .. evo/RA
Old Aug 4, 2009 | 11:53 PM
quikkstylez's Avatar
had a question about motor mounts. im looking to purchase some stiffer mounts, but the only ones i can find are the RRM ones...do any other companies make aftermarket RA mounts?
are evo 8/9 mounts interchangeable with our RA's?
thanks in advance gentlemen...
Old Aug 5, 2009 | 05:43 AM
RalliartN's Avatar
evo 8/9 front mount fits. I believe the other side/rear mounts are different.
I bought a used stock evo 9 front mount in this forum for my RA. It is stiffer than RA and helps reduce wheel hop. Very slight vibration at idle, a nice "middle ground" solution.
I have a hard aftermarket urethane mount waiting to be installed. Me and the car can tolerate a lot more idle vibration if it totally eliminates wheel hop. Do a search here, there are many kinds for sale - probably can't go wrong with any of them. You can get just the insert that presses into your stock steel bracket, or a complete plug 'n' play unit. Get the latter if you don't have access to a hydraulic press.
Old Aug 5, 2009 | 07:02 AM
otter's Avatar
EvoM Administrator
I have AMS' front mount insert (the softer black one.) You don't need a press to install it if you get creative with your other tools. I used a sawzall to remove the stock mount insert (cut the inner collar in two places, then hammered it out with a hammer/chisel) then used my bench vise to press in the AMS mount.
Old Aug 5, 2009 | 11:55 AM
thanks for the info fellas..
i know our evo big brothers have tons of options for mounts, still doing some research...so pretty much any 8/9 front mount will work for our RA's? ill probably purchase a whole mount, instead of just the inserts, you know...for some bling factor. haha.
Old Aug 5, 2009 | 11:56 AM
and one more thing, im still sort of a newb and dont have access to a service manual as of yet. how many mounts does our engine have. to my understanding its 2? correct?
Old Aug 5, 2009 | 12:04 PM
Realistic's Avatar
does it make sense to put in transmission mounts aswell?
Old Aug 5, 2009 | 02:16 PM
these are front mounts correct?
http://www.speedelement.com/index.ph...mart&Itemid=38
Old Aug 5, 2009 | 02:56 PM
RalliartN's Avatar
Yes that is what you want. It's also called a "front roll stopper" just to confuse the crap out of mount newbies.
Old Aug 5, 2009 | 03:08 PM
gotcha, and how effective would it be to only swap out a front mount and not the others?
Old Aug 5, 2009 | 03:13 PM
RalliartN's Avatar
Transmission mounts? Side rear mounts? Try just the stiff front mount first. Then you'll know if it "makes sense" to you to replace any others. If it's handling and wheel hop you want to focus on, the next step is lighter wheels. I replaced my stock wheels with 16"x7" 5zigen fn01rc and Toyo T1R tires to save 8 pounds per wheel/tire over stock. That did more than anything to improve road performance - best money I've spent. From your questions, I'd suggest that bolting the transmission and engine hard to the chassis would be a waste of your money and time.
Old Aug 5, 2009 | 05:34 PM
Those are the exact same wheels i was thinking of getting soon, mind posting some pics? Im curious to see how 16s look, i was considering 17s, dont wanna hijack my own thread but can you throw me.a pm?
Old Aug 5, 2009 | 10:37 PM
MivecLancer1's Avatar
blox makes a front roll stopper that fits
Old Aug 6, 2009 | 05:54 AM
Realistic's Avatar
then why bother getting motor mounts if all you need is decent tires?
Old Aug 6, 2009 | 10:17 AM
took a look at my front roll stopper today, its torn to ****...that might explain my 1/2 gear grind, and hitting the "wall" on my 2/3 shift at higher RPMs. replacement time!
Old Aug 6, 2009 | 11:48 AM
OttRalliart05's Avatar
I have a guy here that can do Alum mounts with poly bushings. He would need 10 confirmed orders before he went ahead. We can use my 05 RA as a template...as the my turbo has "softened" the stock mounts.
Any one in?
