EVO 9 Computer?
Old Sep 29, 2009 | 12:47 PM
kaoscage's Avatar
EVO 9 Computer?
So the Evo 8 ECU work with the base lancer, as long as the ecu is reflashed and retuned. So would the Evo 9 Mivec work with our Mivec lancers?
Just something to ponder.
Old Sep 29, 2009 | 12:51 PM
soulesswarrior's Avatar
Don't think anyones tried. Would prob make it more tuner friendly though
Old Sep 29, 2009 | 01:33 PM
migueralliart's Avatar
Our ECU has 141 pins the EVO 9 ECU has 100 pins, also the EVO 9 does not have an electronic throttle. If the sensors are compatible however one might say there is a possibility to switch to another throttle and manufacture a plug and play harness to swap the ECUS this might be interesting
Old Sep 29, 2009 | 01:37 PM
kaoscage's Avatar
Yes, I have looked into the electronic throttle problem, as mine has giving me plenty of problems. I found a universal delete kit, that might be able to adapt.
OR
if we go turbo we may be able to steal the evo throttle/ throttle body set up, and since we are going turbo may help delete alot of the hassel.
I think I will be contacting my tuner when I get off work.
Old Sep 29, 2009 | 02:49 PM
doesnt one of the galants throttle swap perfectly? and its a wire throttle?
Old Sep 29, 2009 | 04:26 PM
Yes but the EVO computer does not control the throttle YOU DO
Old Oct 5, 2009 | 05:45 PM
otter's Avatar
EvoM Administrator
I know I'm late to this, but something needs to be made clear - the MIVEC on the Evo != the MIVEC on our car. They operate different and the ECU from one car wouldn't likely be able to control it on the other.
