Help power loss at 5k rpm
Old Feb 11, 2010 | 03:37 PM
soulesswarrior's Avatar
Ok so I've been having a p0069 cell off an on since I installed my piggy an timing box. Never had any problems untill past couple days. Today I reset my ecu let the car go through the learn process etc. Well after that I gave it a lil punch and in 1st gear whe. I hit 5 k power loss rpm wouldn't raise and backfire an on pops a cel. But after that it hasn't or won't replicate. Can't pull the code ATM. It happened once befor but it was raining I thought was tires slipping. Any ideas?
Old Feb 11, 2010 | 05:44 PM
slc-ralliart's Avatar
P0069 code is a MAF sensor problem. Don't know why the timing box would throw off the MAF. Clean your sensor, reset the cel and try it again. Also try disconnecting your battery for 15 minutes to reset the ECU.
Old Feb 11, 2010 | 06:41 PM
Well when I disconnect the timing box cel goes away :/ imma see if it will bog out without the box
Old Feb 12, 2010 | 06:26 AM
And the p0069 says it's the map/borometric meter or what not
