broken fog housing
Old Jul 18, 2010 | 08:34 PM
nashvilleRA's Avatar
broken fog housing
my passenger side fog housing is broken, probably knocked loose by a pebble or something. now at speed it wobbles back and forth and at night i can see my fog's beam moving back and forth.
i looked under the bumper and i can see that the top right piece of the housing has broken off with the screw still in it, along with the bottom center screw. i will put up pics if needed, but i just need to ask.
brand new fog housing or epoxy/jerry rig this one?
thanks in advance.
- NashvilleRA
Old Jul 18, 2010 | 08:35 PM
here are the pics. and the video i took, which would be helpful, does not work.
^^^i circled the fog light because i know it is cracked, and is not really the problem now. light output is just fine.
^^^yet another view of the cracked lens. the circled part is obviously broken and i dunno how i should fix.
^^^this is the "top" screw i mentioned. the cord/sheath you see is the fog light wiring, the left side of the picture is toward the middle of the car.
Old Jul 18, 2010 | 08:52 PM
Raikiri's Avatar
honestly i'd just get an entire new housing. you dont want to deal w/ a broken lens as well as attempting to cheap fix the wobble. ask RussellM and see what price he can offer you
Old Jul 18, 2010 | 08:59 PM
Raikiri's Avatar
that or you can always grab these if you were planning on going this route for the color anyway
http://cgi.ebay.com/ebaymotors/04-05...Q5fAccessories
Old Jul 19, 2010 | 04:45 PM
thanks raikiri. those ebay fogs look pretty good. but im also wondering if i need to remove the bumper to install?
Old Jul 19, 2010 | 06:35 PM
Raikiri's Avatar
Yes to make your life easier
Old Jul 19, 2010 | 07:01 PM
hmmm. and i hear i need a rivet tool...
will i need to disconnect any wires and such?
Old Jul 19, 2010 | 07:02 PM
HuMmInGBiRd's Avatar
this happened to mine, duct tape and epoxy for temp fix. i bought some ebay housings and replaced the bulbs with an hid kit. SEXY. worthed it.
Old Jul 19, 2010 | 07:06 PM
that does sound sexy.
although i was thinking yellow fogs and HID heads.
but i guess i could do the other way around, and not have to buy expensive projectors and just get yellow head bulbs?
how did you replace the fogs/housings?
Old Jul 19, 2010 | 09:25 PM
Raikiri's Avatar
im in the process of installing my 3000k HIDs in my fogs right now but in the OEM housings. going to look sick with my 6000k HID headlights! =]
Old Jul 20, 2010 | 02:26 PM
the housings are oem fit, they clip/screw into place. the fog itself is screwed it i believe if i remmeber right.... its been so long
Old Jul 20, 2010 | 07:50 PM
you're right, that will look sick! please post pics when you're done.
humm, i was just wondering if i need to take off the bumper completely to remove the fog housing, cause i cant fit my hands up into the space around it. although i haven't tried it with the car jacked up.
(and i'm a little afraid to, my buddy's Tacoma just fell on him last week and broke his T12 vertebrae.)
Old Jul 20, 2010 | 08:27 PM
lanzerralliart's Avatar
EvoM Super Moderator
You can remove the foglight housing with minor trouble but here's a pic that should help you decide what you need to to...
Old Jul 20, 2010 | 10:45 PM
Raikiri's Avatar
you do need to take the entire front bumper off to work on the fogs comfortably w/o having to work upside down and be confused and everything. it takes a total of like 5 mins or so to get it off.
Old Jul 20, 2010 | 10:59 PM
It's only held on by 4 screws not very hard just take your tome if u strip one then your in for a world of hurt...
