Possible Shift Boot Option
Old Oct 6, 2010 | 03:57 PM
otter's Avatar
EvoM Administrator
Just a cover.
If you find anything for the door, please share. I don't know why Mitsubishi hates padding for your elbows. I'm probably going to buy one of those gel wrist pads for mice and stick it to the door
Old Oct 7, 2010 | 09:05 AM
Antonovich's Avatar
So before I place my order, I just wanted to confirm that the evo VIII option for the armrest will fit perfectly in the 2004 RA?
Old Oct 7, 2010 | 10:35 AM
otter's Avatar
EvoM Administrator
Yes, it will. If you want the padding, though, you have to PM them beforehand. I don't think they have the option for the padding on the site for the Lancer/Evo cover.
Old Oct 7, 2010 | 10:47 AM
Antonovich's Avatar
yeah i been talking with them through email and they confirmed the shift boot size...been really helpful and quick to get back...jsut wanted to check on the armrest. thanks.
Old Oct 7, 2010 | 02:37 PM
Antonovich's Avatar
So I got my order for the armrest and boot. I searched but could find any clear instructions to replace the boot in the RA. Does the grey ring pop off or does the entire centre console need to be removed like the evo below?
http://redlinegoods.com/EvoXinstall.shtm
Old Oct 7, 2010 | 02:47 PM
otter's Avatar
EvoM Administrator
http://redlinegoods.com/Evo8install.shtm
You can probably do it without removing the entire center console, however, the center console is really easy to remove and it'll probably make access easier.
Old Oct 16, 2010 | 11:55 AM
Antonovich's Avatar
got my stuff in the mail....only 5 business days! brought my toolbox to work to put the boot on during my lunch...open it up and realize i left my screw driver out!! ARGH!! the armrest cover looks wicked though. the latch doesn't click anymore but it's still closes down ok. I'll have to put the boot on later....but i'd recommend going with redlinegoods.
Old Oct 16, 2010 | 12:19 PM
otter's Avatar
EvoM Administrator
You sure you put the armrest cover on right? Mine closes exactly the same as it did without it.
Old Oct 16, 2010 | 12:35 PM
Antonovich's Avatar
yeah i did...i pulled it tight so it's tight across the top. it still closes but i don't hear the click anymore. the top, back and front look perfect. I figured it was just the extra material giving a tiny bit more thickness on the clasp edge.
Old Oct 19, 2010 | 11:12 AM
Antonovich's Avatar
So I got the boot installed....looks soooooo good.
Otter...I see i did put the armrest on the wrong way. I took the screws out but there seems to be two plastic plugs holding the top on. I assumed I would jsut have to pull up but they seem to be stuck in there pretty good and i don't wanna break it. How did you get those out?
Old Oct 19, 2010 | 11:55 AM
otter's Avatar
EvoM Administrator
There's no screws under those plugs. You need to remove all 6 screws to seperate the top and bottom half of the armrest. I'm guessing you didn't remove the two screws holding the latch piece. Those have to come out.
