Getting robbed of gas mileage
Old Oct 19, 2010 | 10:08 PM
kayouu's Avatar
Yeah man I work at a Lube shop and not gonna see gas millage dropping from forgetting oil change a bit. Same as someone said above Air filter, I noticed the RRM SRI made my gas millage a lot better. Spark plugs ensure good spark, also always good to check coil packs to ensure that there giving proper power. Tire pressure yupyup other than that... I'd say you could set up a fuel return system...
Old Oct 19, 2010 | 10:27 PM
NorCal Lancer's Avatar
i need to get my spark plugs changed, hopefully that will help. I avg lik 250 miles a full tank. I have to drive like an *** sometimes so I can get to work on time, so I already know thats not helping me.
Old Oct 20, 2010 | 05:35 AM
Thomar's Avatar
Driving normally helps.
At one point, sticking to the speed limits (ok, so, 7 or 8 km/h over) traveling on the highway i've gotten 560km out of one tank, which was fantastic (thats 345.679012345679 miles lol).
Old Oct 20, 2010 | 09:46 AM
Kroelav's Avatar
I get 21 miles to the gallon when I try to drive the speed limit...
Try.
Old Oct 20, 2010 | 05:45 PM
Jabl3s's Avatar
My gas light normally comes on after about 260 miles. which I think is about 26mpg.. Thats not bad considering its 95% city, a lot of rush hour driving and the occasional WOT fun
Old Oct 20, 2010 | 06:51 PM
Darewood's Avatar
You guys should try finding an ethanol free station. It will help out with gas mileage. I actually get 360 for a full tank. And I do drive under mivec sometimes but I also WOT it too. Especially on the straight aways and turns
Old Oct 20, 2010 | 11:09 PM
kayouu's Avatar
Yes most def. non-ethonal if you can find it is obviously proper choice. But yeah I get great gas milage. I do run Premium, just cause the Nitrous though.
Old Oct 23, 2010 | 10:44 PM
Myszkewicz's Avatar
I always get over 300 miles per tank. The only time I didn't was on a 1000-mile road trip on I-80, cruising through the Iowa or Nebraska (all I remember of the scenery was corn. Lots of corn) at about 4500rpm in 5th gear. Not insanely fast, but high enough to be in the upper Mivec range, and stayed that way for the whole tank. Fuel light came on at about 230, and I stopped to fill up at 250. Then I slowed down a bit when I got back on the road, and my next tank was around 320.
I gave some thought to putting in a switch I could turn off for highway cruising, but then I moved and don't drive my car much anymore (only about 2500 miles this year), and now enjoy getting 40+ mpg on my bike.
Old Oct 24, 2010 | 02:41 PM
Raikiri's Avatar
my gas light usually comes on around 280 miles.... i dont know how you guys get above 300 unless being of course you're tuned for better mileage
maybe being A/T has something to do w/ it?
Old Oct 24, 2010 | 02:47 PM
400whp350wtq's Avatar
GEt used to it. Mileage on these cars suck kinda irritating but thats what happens with a turbocharged car i guess
Old Oct 24, 2010 | 02:53 PM
Raikiri's Avatar
you do realize you're in the lancer section yes? lol not all of us are turbo'd
Old Oct 24, 2010 | 10:07 PM
mrwilsonsaid's Avatar
i get about 300-315 miles to the tank. Today i was driving back to school and wanted to see how far i could get after the gas light came on. 40 miles later, the car started to give in. Luckily there was a gas station not to far.
Old Oct 24, 2010 | 10:25 PM
Raikiri's Avatar
good to know how far i can get w/ the stupid light
Old Oct 25, 2010 | 04:57 AM
nekkidlad's Avatar
SPEAKING OF GAS LIGHT...
is it just my car or does every1 else's do this too..?
my gas light turns on while im driving...and then shuts off...2 or 3 times (not like flickers..but like stays on for a minute or 2 then goes off for about another min or 2 again etc)...and then it turns on and stays on...
i know maybe the gas sloshing around in the tank may be it...but it ussually happens on the highway when its like dead straight and barely any bumps too...so theres minimal movement...any thoughts..?
i thought maybe fuel pump/sending unit..?..not that ill replace it...it still works...i always just wondered about it...
Old Oct 25, 2010 | 08:10 AM
i dont think anything is wrong. my car did that on the highway yesterday too. i started counting the miles after the gas light came on for the first time. it turned off and on a couple times but i think its normal. it really gave me a scare when the car was gasping for more gas
