HVAC Control lights
Old Nov 8, 2010 | 06:31 AM
Antonovich's Avatar
HVAC Control lights
I've seen a lot of threads about colouring the lights and such, but my issue is that the right side is illuminated (air flow direction) but the left side isn't (temp dial) I have no idea where to start to fix this.
Old Nov 8, 2010 | 09:09 AM
Jabl3s's Avatar
There's a "How to" on changing the HVAC bulbs.
https://www.evolutionm.net/forums/04...vac-bulbs.html
I'm assuming a bulb of yours is out. If not, then maybe a loose connnection?
Old Nov 8, 2010 | 09:13 AM
Antonovich's Avatar
Thanks hopefully changing out the bulb works
Old Nov 8, 2010 | 03:25 PM
Boushard's Avatar
I have the same "problem" but a little tap on the bezel and the light came back!!!
