Wow!.........
Old Jan 22, 2011 | 03:45 PM
Thomar's Avatar
Thumbs down Wow!.........
Went on a casual drive today and stopped at north side mitsubishi to book a service appointment for the 78'000km service (consisting of an oil and filter change).
The service rep advised that it would be 512 dollars, due to the mechanics adding a pH balancing thing to the coolant, checking the spark plugs and the brakes for wear, blah blah...
After a brief discussion about what the 78'000km service consists of as per the maintenance manual, I was informed that some of the things listed on the piece of paper he showed me I "didnt need anyway". I couldnt help it but responded with a "i dont need any of em".
But wow... now for only an oil and filter change they are charging me 61 bucks. Still, a bit on the high side, but whatever.
Old Jan 22, 2011 | 04:13 PM
GearDownSon's Avatar
What was on the list?
Old Jan 22, 2011 | 04:28 PM
Thomar's Avatar
just various things like check sparkplugs, brakes, coolant, etc...
Old Jan 22, 2011 | 04:29 PM
Pffff
Thus why i do all things myself.
Old Jan 22, 2011 | 04:45 PM
Antonovich's Avatar
wow.........
if a shop did that to me, i would find a new shop. I wouldn't wanna deal with shadey people.
Old Jan 22, 2011 | 04:47 PM
milford's Avatar
i hope you didn't say ok to that
Old Jan 23, 2011 | 02:04 PM
Thomar's Avatar
skdjf
Old Jan 25, 2011 | 08:40 AM
xmaster19's Avatar
Changing whole cooling fluid, using approved coolant and distillated water : 40$ MAX
Changing spark plugs to platinum's : 100$ MAX
Changing all pads : 100$ MAX
Getting ripped off : Priceless!
Old Jan 25, 2011 | 09:03 AM
nekkidlad's Avatar
thats if you do it yourself...
if ur at a shop add at least $100 to each of those for labor..
still even for full synthetic and one of those high mileage filter i wouldnt pay $60 for an oil change...
Old Jan 25, 2011 | 04:19 PM
Flip's Avatar
Originally Posted by GearDownSon
Pffff
+1 my oil changes are like $30 with the mobile 1 oil + filter special at advance.
its all full synthetic too.
my timing belt change is the only thing im having a shop do for me. i just dont have the time to do it, and the labor is really cheap.
everything else ill do myself. that way you can learn a bit more about your car and how it all works.
-Flip
Old Jan 25, 2011 | 05:30 PM
Thomar's Avatar
Even at quick lubes an oil change will cost around 50 bucks, so another 10 bucks is ok. plus they usually spray off my car when I bring it in dirty. if i had a garage id do it myself, but I don't, so I'm not. I'm not a fan of laying in the mud and snow.
What I'm trying to point out is how they are turning a simple oil change into a 3 hour service. The sad part is that most people would just agree to that nonsense and get raped royally.
Old Jan 26, 2011 | 01:18 PM
biglou360's Avatar
they allways try to pull that on me, thats why i did all the work on my car.
Old Jan 26, 2011 | 01:30 PM
Raikiri's Avatar
how often do the spark plug/coil packs need tobe changed? im thinking of getting new plugs. we use the iridium sparkplugs right? would going to platinum be a downgrade?
Old Jan 26, 2011 | 02:15 PM
Beardly P's Avatar
Hail to the Beard
I think it's at 30, 60, and 90k service. I'm going to replace mine at my 90k service, didn't do it at 60k.
Old Jan 26, 2011 | 02:23 PM
nekkidlad's Avatar
i believe spark plugs are recommended at around 30k i believe and the coil packs dont need to be replaced at all unless theygo bad....then ull know by a misfire..
