turbo
turbo
how much boost can the stock internals of on 04 ralliat can handle i want more boost but dont wanna blow my engine what all should i change to get more boost if i tear the motor down right now im at about 4psi
You can get around 10 psi at most stock , without having to worry to much but it will have to be tuned correctly. I'd say 8 psi is a fair safe range to be in stock but if you build up the sky is the limit. How much are you looking to spend?
