blox roll stopper install issue
The roll stopper is threaded in to bottom. the mount on the cross member is through the top. My crossmember is two pieces welded together so i can't bolt it up underneath. Is everyone esles like that and woukd it hurt anything if I blew holes big enough to get a socket in there to get the bolts in ?
I'm having a hard time understanding. I had the blox front mount and it was an easy install....can you take pics of what you mean? And pics of whats causing the issue? I dropped the crossmember right out with the mount bolted to it still, changed the mount and put the crossmember back in.
you may have the wrong roll stopper, if i'm not mistaken, the one for the Evo X is very similar, but threads through the bottom. Our engine roll stopper, like the Evo 8/9 is not threaded, bolts on from the top, and is fairly simple to install as rob has said...
Then that would prolly be my problem. does anyOne know if they're the same size? im sure i can make it work if the are. i have compared sizes with old one and i know the roll stopper is bigger but i dunno I cant tell ftom pics.
Hennybenny
Lancer How Tos / Installations
Jun 15, 2015 09:23 PM
TommiM
15
Sep 30, 2014 04:46 PM
CrAnSwIcK
14
Oct 8, 2013 12:07 PM
MISHI
Dec 16, 2011 07:24 PM
MR White
Dec 5, 2009 12:00 PM
