Valve tick at low rpms?
Old Oct 1, 2011 | 10:01 PM
Thomar's Avatar
Hey guys,
I have this ticking coming from the engine, sounds like the valves, between about idle to 1800rpm, when accelerating from a stop or otherwise. Seems to completely disappear at around 2000rpms and above.
I set the valve lash (car has 91000km on it now) but that didnt change it much.
The car is due for a timing belt change in 5000 more km's.
Any ideas?
Old Oct 1, 2011 | 11:32 PM
CrAnSwIcK's Avatar
mine ticks...is it like super loud? was the lash adjusted hot?
Last edited by CrAnSwIcK; Oct 2, 2011 at 08:40 AM. Reason: grammar correction durr
Old Oct 2, 2011 | 04:12 AM
lanzerralliart's Avatar
EvoM Super Moderator
Are you sure your not hearing the fuel injector pulse ? It sounds very similar ....
Old Oct 2, 2011 | 10:24 AM
Thomar's Avatar
It's loud enough to hear it with the windows down. And yes, it was adjusted hot.
I have no idea. Sounds mechanical to me. Sounds like the valves.
Old Oct 2, 2011 | 10:36 AM
CrAnSwIcK's Avatar
how many k since your last oil change, and is it full?
Old Oct 2, 2011 | 02:18 PM
Thomar's Avatar
yeh its full of oil, running mobile 1 synthetic, has 6000km on it now. running the same oil for 12000km. its not the oil.
Old Oct 2, 2011 | 03:11 PM
CrAnSwIcK's Avatar
i don't know man, if it's really loud it could be valves/rockers, but if it's pretty minor it could be normal...as i said mine has a slight tick, and i've had my head completely rebuilt within 20k, and it ticked from day one, i did the valve lash the day after first start-up after the rebuild.
Old Oct 2, 2011 | 03:56 PM
Thomar's Avatar
hm.
Old Jan 8, 2012 | 03:27 PM
Thomar's Avatar
Wanted to update this thread following me doing the 96'000k service.
The valve tick has completely disappeared since changing the timing belt. So, anyone also having valve noise/ticking at low rpms, it appears to be signs of an ageing timing belt (provided that the valve clearance is within spec).
Old Jan 8, 2012 | 04:04 PM
keithislegit's Avatar
How much did it run you to do the timing belt?
Old Jan 8, 2012 | 04:37 PM
Thomar's Avatar
Well, I didnt just do the timing belt. I also changed the water pump, and all pulleys.
Look at this thread for the parts:
https://www.evolutionm.net/forums/04...arts-list.html
Cost me around $750.
Old Jan 8, 2012 | 05:28 PM
dacib's Avatar
If you are somewhat mechanical inclined you can do it yourself, it's very easy.
Old Jan 8, 2012 | 09:17 PM
Thomar's Avatar
It's not too easy... special tool MD998738 will help a lot in setting the timing belt tension. If you have the service manual it will definitely help u in showing you what you need to remove to get at the timing belt, etc.
If you feel unsure, enlist the help of a mechanically inclined friend.
Old Jan 10, 2012 | 11:56 AM
nekkidlad's Avatar
theres 2 special tools for the timing belt change...one is required(pulley holder tool) the other is very helpful(threaded rod) but not required...specially if ur doing the tensioner
i did my belt, pulleys, tensioner, water pump(2x..grr) w/ gasket and thermostat(also 2x...grr) at about 100kmi...the parts cost me around $350 and i did the work myself w/ otter at his house...took us about 3 hours or so if i remember correctly(plus the time it took us to drive out to parts store and buy 2nd t.stat)
i wanted to do the valve lash too, but i forgot to order a valve cover gasket...and figured id just do it myself later...(about 25kmi later...and still not done..lol...still meaning to do it tho..)
i can def. hear the valves tick but it drives just fine for now, no roughness or anything..maybe ill just get to the valves when i do the next belts...lol(if it doesnt drop or bend a valve somewhere in the meantime..lol)
Old Jan 10, 2012 | 02:47 PM
I had my caliper out and saw the pulley and this thread earlier so incase someone is up for making a tensioner tool out of some thicker solid gauge wire here are some helpful measurements.
Hole to hole closest O< >O 10.78mm
Hole to hole farthest >O O< 17.40mm
Hole 3.40mm wide
Hole depth 7mm
Dacib and I made one with a solid aluminum tube bent like a staple and a flathead screw driver it worked just fine.
