starter problems again...er...
Old Mar 28, 2012 | 07:16 AM
nekkidlad's Avatar
so...had problems with the starter in october...
bought a new one, installed it all good...
december comes around...starter problems again...take it out bench test it...just makes noise...nothing happens...get it warranty exchanged...put the new one in...all good again...also installed new upgraded battery(OE ~600cca, mine: 800cca...warranty also...) and a new negative battery cable end(the old one was stretched and the tightening bolt was seized..it would pressure fit on there but you could easily slip it on and off the battery)...tested the relays in december and theyre good...also checked fuses also good...as well as the starter switch...also checked resistance and terminal conditions all good, no corrosion or loose terminals(after replacing the battery terminal..)
now march...starter problems again....started last week...now today had to push start it again...talking to customer service right now trying to get a new warranty exchange again...
anybody having anything similar to this..?
i know in my original thread(this is the 3rd...) "ressurrected RA" posted he had ordered one also...if you see this and have any input...please post...
my car is all stock...only mods are viper alarm(came on when i bought the car)stereo head unit(also came on when i bought the car), SRI(also came on when i bought the car) and shifter bushings..nothing that would affect the starter, ive had the car for 3 years with the samethings on it...
