Drivers seatback tilted to the inside?
Old May 10, 2012 | 08:51 AM
lanzerralliart's Avatar
EvoM Super Moderator
Originally Posted by 2006_RA
I thought airbags were standard equipment on the Ralliart, kind of has me down now knowing I have 2 lumps of deadweight in my car that could have been avoided.
From what I'm looking at the SRS airbags are optional equipment with LS and Ralliart lancers 04-05 , I don't have the info for the 06 but it would only make sense to have it optional as well.
I wouldn't be down, that deadweight might prevent you from becoming "deadweight" one day
Old May 10, 2012 | 09:10 AM
TooSteep's Avatar
Srs
Ahhhh , that's what the red SRS light on my dashboard means! I was wondering about that. I also see a couple of shielded tubes running to my seat - I assume those have something to do with the airbags.
Any idea what I should expect to pay for a reclaimed seat from the salvage car?
Thanks.
Old May 10, 2012 | 10:10 AM
2006_RA's Avatar
I saw one priced at $150 on mypartshop.com.
Old May 10, 2012 | 11:29 AM
floating doc's Avatar
I was complaining earlier in this post about how uncomfortable my seats are. Well, I had my wife drive while I sat in the passenger seat. The foam in the driver's seatback must be broken down; the passenger seat wasn't nearly as bad.
My driver's seat has no lumbar support at all; I have to put a small pillow behind my back.
Old May 10, 2012 | 11:32 AM
CrAnSwIcK's Avatar
had this problem too, the wire supports across the back were broken, you can just curl the ends of the wires with pliers and vice grips, to make a loop, and tie the wire together with flexible metal wire, or strong string...
Old May 10, 2012 | 05:50 PM
2006_RA's Avatar
If you guys would have your fun in the back seat, your front seats would last longer
Old May 12, 2012 | 06:18 PM
Back seat? Why do you think I've owned SIX station wagons?
As for CrAnSwIcK's comment on repairing his seat back: I'll bet mine has the same problem. I'm don't want to take apart a seat with an airbag/explosive charge without knowing more than I do. I'll probably get a pro to do it if I keep the car (and that's still up in the air).
Old May 13, 2012 | 12:21 AM
CrAnSwIcK's Avatar
straight up the back unzips, have a peak in there, i bet you'll find something outta whack..
Old May 13, 2012 | 04:10 AM
My drivers seat is alright, although about a year ago I heard some metal rattling from it. I opened up the bottom from the back and a one foot metal rod about the diameter of my pinky fell out. The seat still feels the same and weight reduction lol.
Also the mesh grille on that ra is aftermarket , try to snag that too. I'd also say take the MAF, TPS, and the FCM if they can be had for a decent price. Pop the hood it might have an intake or headers, since it was clearly modded.
Old May 21, 2012 | 02:40 AM
Resurrected RA's Avatar
Originally Posted by Raikiri
they should be. snag those tail lights too!
if they're in good condition you either upgrade yours or can always sell them here on the forum for maybe more than what you'll pay the salvage company
Those tail lights look scratched and/or cracked. The PS tail light is definitely fubared.
Old May 21, 2012 | 02:50 AM
RoMeIX's Avatar
I would consider a new seat if the seat actually is damaged from a previous accident. For safety reasons alone I would consider changing it. Also depending on if you do track the car at all, it could be a good time to upgrade to something more comfortable/performance oriented, and lighter.
Old May 21, 2012 | 10:20 PM
TooSteep's Avatar
I am headed out there this week. Not being too bright, could someone please tell me what the MAF, TPS and FCM are?
Thanks!
Old May 21, 2012 | 10:22 PM
TooSteep's Avatar
Originally Posted by RoMeIX
... Also depending on if you do track the car at all, it could be a good time to upgrade to something more comfortable/performance oriented, and lighter.
If I do go the 'new seat' route, what would you recommend?
Thanks.
Old May 21, 2012 | 10:49 PM
RoMeIX's Avatar
Thanks.
My buddy replaced his with some sort of Recaro that seem to be a big improvement over the feel of the stockers. I have also heard that Evo 8 and 9 seats bolt right in and plug into the same harness the stock seats did, but may require a dealership to turn off the SRS light, (caused by a different seat/airbag replacing the stock set up). There is info about the swap you can find with a google search.
Old May 22, 2012 | 05:49 AM
2006_RA's Avatar
Thanks!
Mass Air Flow sensor, Throttle Position Sensor & Fan Control Module.
