Headlight issues,
Old Jun 29, 2012 | 04:50 PM
mikegutt's Avatar
Headlight issues,
Hey guys, just wondering, i have the blacked out projector headlights, and on my right side light on the h1 highbeam assembly, the ground screw stripped i guess, and the metal bracket snapped, tried grounding out the ground other places but the light still wont turn on, any ideas?
Old Jun 30, 2012 | 11:23 AM
RacerX-Ralliart's Avatar
Are you grounding it to a well known ground? Make sure your not trying to ground it to a painted surface and if the only place you can ground it to is painted you can sand it off but idk if you want to do that.. To if it works you can use a alligator clip and hook it up to the ground on the battery if it still doesn't light up might be something else
