Noise from rear windows
Old Jul 31, 2012 | 07:32 AM
Huetsimus's Avatar
I have a question for the minds. My rear windows make a sound when I first roll them down. It sounds like they are stuck to the rubber and break loose. The front ones do not have this problem. I have tried different window cleaners, thinking some might leave a film that makes it stick with no luck. I am checking to see if others have had this happen. Thanks in advance.
Old Jul 31, 2012 | 07:35 AM
roblaza's Avatar
Mine do that the odd time aswell...especially after it rains and has time to dry. I wouldn't worry about it too much unless its scratching the glass.
Old Jul 31, 2012 | 10:00 AM
2006_RA's Avatar
Spray the rubber with silicone lube. Do the same for the door, trunk & bonnet gaskets too.
Old Jul 31, 2012 | 10:20 AM
roblaza's Avatar
wont that give him streaks on the glass?
Old Jul 31, 2012 | 10:22 AM
nekkidlad's Avatar
sometimes i do have a kind of "rubber is stuck on the glass" noise sometimes but like said above...dont worry unless it starts to scratch the glass and maybe try some silicone lube on the rubber...
PS: speaking of windows...does any1 else's window move like 2in. if u grab the glass and pull it up/down(so long as its not full open or full closed position)..?
doesnt seem to affect anything but i noticed this recently cleaning the windows...i havent goten into checking it out but i know the glass is not detached fromt he regulator(aka moving mechanism)...
Old Jul 31, 2012 | 12:36 PM
Huetsimus's Avatar
Thanks for the tips. It does not scratch the glass, but just sounds hurtful to me. I am picky. I will check into the silicon lube on the rubber. Also, about the windows moving, almost all will to some extent. Mine are tight for now. I have cleaned new car windows and had them move a bit. Might be just a simple tighten of the mechanism.
Old Jul 31, 2012 | 04:42 PM
2006_RA's Avatar
It doesn't stay wet, it has a residual effect.
Old Jul 31, 2012 | 06:01 PM
roblaza's Avatar
Ahhh, gotcha. I wasn't sure.
Old Jul 31, 2012 | 10:20 PM
Raikiri's Avatar
have you checked to see if the rubber around the windows is fully seated? my brother had this problem on his windows when he got his windows tinted.
Old Aug 2, 2012 | 05:37 AM
RalliartN's Avatar
This. I treat all those rubber surfaces, and it really pays off over the years. Silicone spray is mandatory treatment for older Subarus where there is no metal door frame surrounding the windows, the glass just presses against big rubber seals; siliconing the rubber every few months stops all noises and keeps the rubber looking new for a decade.
Any excess silicone just wipes off the glass, cannot hurt anything.
Do this during the winter and glass/metal will never freeze to the rubber seals - your doors will not stick shut and the windows will always wind down.
Interestingly, I've noticed most people don't do this kind of upkeep.
Old Aug 2, 2012 | 09:02 AM
nekkidlad's Avatar
why would anybody do it...most ppl think doing an oil change 1nce a year and only that maintenance will keep their car running fine forever
Old Aug 2, 2012 | 10:07 AM
2006_RA's Avatar
And that's what you count on in your profession nekkidlad, isn't it LOL
Old Aug 2, 2012 | 10:09 AM
nekkidlad's Avatar
NOooooooo....*SHIFTY EYES*
hehehe
