Questions about strut parts/numbers
Does anyone know if the upper spring plate, upper strut mount and the bearing that sits on top of the spring plate are the same on all Lancers or do we have a distinguished part?
Do you know the part numbers?
https://oemmitsubishiparts.com/parts...iagram=6291178
the bearing that I am referring to is between #8 and #13, it sits on top of the plaate.
I know the shocks, struts and spring are different, but are the upper strut mounts(the piece inside the enigine bay), and the upper spring plate(the piece that sits in the fenderwell at the top) the same on all Lancers? I could just use an ES assembly if they are the same.
it thought they were all different...between the three i think the springs are different diameters, so the seats should all be different, but the mounts should be the same. The OZ may spring seats might be similar, but i don't know...
the reason i was thinking they are the same is that the tein site had the springs the same for ralliarts and oz. that being said i would think the spring seat should sit the same.
Posted from Evolutionm.net App for Android
InoNothingMR
Jan 3, 2013 03:15 PM
