What can you do to make engine faster?
Old Sep 12, 2013 | 12:46 PM
CrAnSwIcK's Avatar
lol, what are you spraying for nitrous? can you post pics of your setup? when you're spraying, it should be plenty fast...however, I hate nitrous setups, cause they are dangerous, and need to be refilled...
if nitrous isn't doing it for you, you will need either a turbo setup, supercharger, or if you want to stay naturallay aspirated, you can build a high compression motor...
Old Sep 12, 2013 | 03:44 PM
blackralli's Avatar
Originally Posted by bakuro117
LMAO! hackFISH greatest typo ever!
No turbos arent cheap at all 2-3000 would get you into the homemade turbo ball park. But really the sky is the limit depending on how far you want to go with a turbo setup.
HACKISH is a guy in Ottawa Canada that has cracked our ECU and thus can program it for better performance. If you get a tactrix cable and get ahold of him or OttRalliart then they can set you up with the tune. Several members on here have it and absolutely love it. You can reach them at UVtune@gmail.com
Regardless though. Given your current setup you may gain a little bit here or there. But if your really wanting to make power you need to either begin piecing together a turbo kit or saving up for a supercharger. Hackish can tune for either of them as he used OttRalliart's RA to test both. Ive witnessed the power of forced induction on these cars on multiple occasions now and its really the only way your going to make the car really come alive power-wise.
Hackish* haha
and how much does that set up cost?
Old Sep 12, 2013 | 03:48 PM
blackralli's Avatar
I bought the car not to long ago from a dealer, it was already set up and I know I will not be using it because i heard the tanks are expensive . Most likely i will save up for a turbo.
I will take pictures of the car and engine when i get it back from the shop, the fourth day with the car and an expedition rear ended my RA .
SmurfZilla
Aug 16, 2015 03:50 PM
hiner005
12
Jun 28, 2014 11:32 AM
kpt6
Mar 21, 2014 05:12 PM
rcantu
Feb 21, 2014 07:43 PM
