04 Ralliart won't start.. HELP!!
Old Oct 28, 2013 | 06:18 PM
TheMort's Avatar
New to this forum, just purchased my 2004 ralliart two weeks ago and it's been running like a champ. Got back form a 200~ish mile drive and parked it in my driveway, went to start it the next day, it turns over, but won't start.
Continues this as I try a few things, a few hours later when I try to start again, it seems to be turning over even slower, almost "bogged" down.
Went and bought a new battery, I needed one anyway, and problem still persists.
All lights/electronics work perfect however.
I'm thinking maybe something to do with the Fuel Pump/relay. Not super mechanically inclined, and a little unfamiliar with this car since it's still new to me.
Any help would be greatly appreciated, thanks!!
Old Oct 28, 2013 | 08:31 PM
CrAnSwIcK's Avatar
how many miles?
before you crank it any more, take the upper timing cover off...get someone to turn it over, and make sure the timing belt is moving, if it's not, stop cranking it immediately, and never do it again, until the timing belt is replaced. and hopefully the valves are not damaged.
If the timing belt is turning, the next thing you want to do is scan it for DTC's...a failed crank angle or cam angle sensor will not allow the engine to start...you can also check for spark and compression, if everything checks out, it could be a fuel delivery issue...
Old Oct 28, 2013 | 08:59 PM
TheMort's Avatar
Originally Posted by CrAnSwIcK
how many miles?
I believe it just hit 168,000 - so up there pretty far.
I'll try this tomorrow, hope I haven't hurt anything so far by cranking a little here and there.
I'll respond back after trying again.
Old Oct 28, 2013 | 10:18 PM
CrAnSwIcK's Avatar
I think there's only 3 or 4 10mm bolts holding the upper cover on...doesn't take much to get it off...and 168k miles is pretty high, not the highest on here, but definitely up there...do you have any of the service records?
Old Oct 29, 2013 | 06:55 AM
slc-ralliart's Avatar
This same thing happened on my car when the original battery died. My car was running fine and then it just died on me and would just crank. After two tows and 6 hours spent at the dealership undergoing diagnostics, the culprit turned out to be two blown fuses underneath the dash.
I would pull each fuse individually and double check to make sure none are blown. Remember there are both fuses in the engine bay and underneath the dash.
Old Oct 29, 2013 | 05:23 PM
TheMort's Avatar
Just checked all the fuses, they look good. Just fuses, or should I check the relays too? I think there has to be a fuel pump relay, is it possible that is causing this if it went bad?
Going down to take the timing cover off now, I'll let you know what I see there.
Also, is there a fuel pressure regulator I could try to check somewhere also?
Random, and probably unrelated, but I have this red wire coming from what appears to be my firewall then comes directly upward, bends 90 degrees towards the front of the engine bay, and then ends, appears to be burnt or cut? I'm just curious as to what this is.
Old Oct 29, 2013 | 05:52 PM
TheMort's Avatar
Also, when I turn key to on position, I hear a clicking noise for around 3-6 seconds.
My check engine light, battery light, and oil light all come on when the key is in the on position, and then the check engine light goes off after about 20 seconds.
Old Oct 29, 2013 | 08:58 PM
CrAnSwIcK's Avatar
for the red wire, I have no idea what that could be...
there are two fuel pump relays, both behind the dash...
I'm pretty there's no stand-alone FPR.
The clicking noise when you turn the key is most likely the throttle control motor/actuator...that's normal...
check that timing belt.
Old Oct 30, 2013 | 02:05 PM
TheMort's Avatar
If I checked the correct relays, they both work. Took out the back seat and ran wire directly to the fuel pump, appears to start up when powered.
However, when I took off the oil fill cap and looked in the valve cover there was nothing moving when being cranked. I'm assuming this means the timing belt is shot?
Old Oct 30, 2013 | 09:37 PM
CrAnSwIcK's Avatar
nothing moves...you timing belt may be broken or stripped...take the cover off to be sure...
Old Nov 1, 2013 | 08:54 AM
mikemike396's Avatar
5 minute job.. Take the Timing belt cover off. Its 3 bolts I think. Maybe 4.... I would do this before checking anything else.
Old Nov 1, 2013 | 09:56 AM
bakuro117's Avatar
Yea you are potentially causing more damage by attempting to crank it without taking a good look at that timing belt...
Many stories on here off the timing belt breaking for whatever reason then the valves get beat up by the pistons and its generally not pretty...
Old Nov 1, 2013 | 10:46 AM
TheMort's Avatar
In school so I've been so swamped I haven't even had a chance to check until this weekend. Thanks for all the help guys! I'll take a look at that timing belt though, haven't been cranking it much, so let's hope.
lancer586
Lancer Troubleshooting
42
Apr 10, 2021 02:16 PM
sxperia101
Apr 8, 2016 06:25 AM
Wmu240
Dec 18, 2015 10:18 AM
Wmu240
Sep 8, 2015 06:21 PM
ChefJMB
Jul 13, 2013 10:13 AM
