Running hot 🔥
Old Jul 31, 2016 | 06:44 PM
Lancerfry30's Avatar
Running hot 🔥
During my most recent drives. I started to notice that the engine temperate goes up with the AC on and goes down with the AC off to normal half way temp levels. ( during driving and idle ). I checked underneath no coolant leaks , correct levels, no oil leaks , AC Blows cold.
Any thoughts ?
Old Jul 31, 2016 | 11:25 PM
CrAnSwIcK's Avatar
does the fan come on?
Old Aug 1, 2016 | 07:02 AM
Good question. I didn't check that. It is going to the dealer for that air bag recall this morning. So I can have them check into
Old Aug 1, 2016 | 04:17 PM
Correction the AC fan does turn on. so does the radiatior fans.
Old Aug 2, 2016 | 06:12 AM
Looks like it needs the AC fan assembly. Dealer wants $405 plus installation. Does anyone/used any aftermarket fan assemblies ? Like the ones o reillys auto part sells
Old Aug 2, 2016 | 11:45 AM
CrAnSwIcK's Avatar
A/C condenser fan is $47 on rockauto.com...and it takes like 10 minutes to replace it. Are they sure the fan control module is working correctly?
Old Aug 3, 2016 | 06:46 AM
Cool thanks. I will order one ASAP. It almost seems like the fan turns on and off intermediate. i might have to check the voltage of the module. The fan motor itself doesn't operate at the correct voltage.
Old Aug 3, 2016 | 07:02 AM
CrAnSwIcK's Avatar
if A/C is on, that fan should be running...the rad fan on the driver's side will turn on and off as it regulates engine temperature...
Old Aug 4, 2016 | 05:38 AM
The fan doesn't turn on with the AC on at all. I ordered a fan from rockauto. Should be here Friday. While I'm there I will check the control module.
Old Aug 4, 2016 | 06:33 AM
CrAnSwIcK's Avatar
In post #4 you said the fan DID come on.
Old Aug 5, 2016 | 05:39 AM
I did notice the fan spins at a really low rpm. I check the voltage/ direct connected to a 12v source and it barely spun up to operating speed and then it would just stop.
Old Aug 5, 2016 | 05:55 PM
CrAnSwIcK's Avatar
motor could be toast...make sure you post up after the new fan is installed...
Old Aug 6, 2016 | 08:23 AM
Here is the original one. Look at how ineffecient the mounting plate was. The motor was toasted.
This is the rock auto one 14inch fan. I double Checked the part numbers over and over. But I guess it's universal. It fit with removal of the upper radatior hose and a header shield bolt and it slide right it. As soon as I turned the AC on. Man does this thing cool.
Old Aug 6, 2016 | 12:00 PM
CrAnSwIcK's Avatar
It's just a fan, the important things are the connector being the same, and it not falling off, lol
Kelzendless
For Sale - Wheels / Tires
Jun 26, 2016 01:23 PM
Brian Chen
Northwest Region
Jun 13, 2003 04:47 AM
