Low heat when cold out
Old Nov 20, 2017 | 09:00 AM
JTCB's Avatar
Hey guys.
As soon as it starts getting cold out my heater doesnt get very warm or it takes forever. Car heats fine gets to normal operating temperature within a couple mins! The colder it is outside the less heat I get in the cabin. When its freezing out I have to put on recirculation or I get no hot air at all. Anyone have any clues as to what I should be looking for?
Thanks
Old Nov 20, 2017 | 05:10 PM
05evolution8's Avatar
might sound dumb but did you check to see if you are low on coolant? i had a truck do the exact same thing and it was a little low on coolant.
Old Nov 20, 2017 | 06:58 PM
BuildingUp's Avatar
Veteran: Army
Mine does the exact same thing and the coolant isn't low. Let the car warm up a bit then start driving and it will blast hot air. I suspect that was a problem with the car that Mitsubishi waited to fix or something. Check the coolant though.
Old Nov 22, 2017 | 12:20 PM
bakuro117's Avatar
If your thermostat is removed or stuck open your heat will behave the exact way that you are describing.
LancerShop.com
Lancer Vendor Classifieds
Oct 27, 2016 06:25 PM
speedfreak24
Feb 15, 2010 08:35 PM
Show Off
Feb 25, 2008 10:52 AM
acidandroid
May 6, 2005 11:15 PM
cacrawfo
AEM EMS
Feb 8, 2004 08:13 PM
