Installing Underhood Brass Shifter Bushings
Old Mar 4, 2006 | 07:04 PM
  #31
Ride_59's Avatar
Finally got it!! Had to use a vice, a block of wood, and a big socket...but it finally went through.
Old Mar 5, 2006 | 07:55 AM
  #32
mitsutech005's Avatar
yeah we used a c clamp and a large socket to get the smaller bushing in.
Old Mar 5, 2006 | 08:23 AM
  #33
Ride_59's Avatar
Maybe we should get them to add that step to the directions. lol
Old May 8, 2006 | 05:32 PM
  #34
boozeup&riot's Avatar
I've also just installed these and I like the results so far. Can't complain for $30~ now I definately want the short throw and solid motor mounts
Old May 8, 2006 | 06:13 PM
  #35
lanzerralliart's Avatar
EvoM Super Moderator
sounds like a good mod since i have the b&m short shifter already........
Old May 8, 2006 | 06:55 PM
  #36
Myszkewicz's Avatar
I had to use a gear puller today to get mine off. The salt from this past Winter got in there and corroded between the pin and the bushing, so my shifter was practically stuck in neutral. Made things a little difficult to drive.
I popped out the brass bushings, cleaned the pins off with a rough rag, greased everything up and put it all back together. Works like it should again.
Old May 8, 2006 | 11:02 PM
  #37
otter's Avatar
EvoM Administrator
Heh, I tried to pull mine out a couple days ago, since they're starting to squeak and getting stiff. Couldn't get the damn things out. Gave up and sprayed them down with WD-40. Got rid of the squeak and shifter feels better. I'll spray them down every few days for awhile, then try to remove them again to sand and grease them properly.
Old May 9, 2006 | 08:41 AM
  #38
I was actually kinda concerned about this since it took a great deal of squeezing to get the smaller one in. Besides them getting a little gunked up, what sort of maintenance if any, do I need to be concerned with?
Old May 9, 2006 | 08:58 AM
  #39
Myszkewicz's Avatar
I had trouble with the small one, too, until I pulled the cable out of the bracket that holds it in place. Then the bushing was easier to line up, and pushed onto the pin by hand. Once I got it started, I put the cable partway onto the bracket and pushed them both on at the same time.
They'd probably be fine if you pull them off every year and grease them, or shoot some oil or WD-40 on them every oil change. I found out what happens when you let them go too long up here. Damn salt.
Old Sep 2, 2007 | 11:20 PM
  #40
LithiumX's Avatar
Just to be sure.. on speed source there are 3 different ones Mitsu, mitsu big and mitsu evo8 and 9
order the Evo for the RA right ? or ne other links ?
any other updates or heads up i m thinking of doing this soon
Old Aug 21, 2008 | 08:49 AM
  #41
isaac085's Avatar
Mitsu,
mitsu big
mitsu evo8 and 9
which one i have to order.
help me pleace
Old Aug 21, 2008 | 12:30 PM
  #42
Drunkendori's Avatar
I'm having some problems installing mine. The small bushing looks too small and the larger ones look too big. Or am I missing on something?
I believe I have to install the larger bushing onto the loop below. But both the stock bushing size looks the same.
From this picture I think you can see it quite clearly that this piece is too big to fit into the gold rim. I think it supposed to go to the one below but its still too big to fit in.
My thread asking for help with pictures here.
https://www.evolutionm.net/forums/sh...d.php?t=364727
Thanks in advance.
Old Aug 21, 2008 | 12:50 PM
  #43
rdc's Avatar
rdc
It's been already talked about a couple of times, the RA uses the same shifter and linkage as the Evo 8-9 (excluding Mr) so use the one for the Evo.
Old Aug 21, 2008 | 02:58 PM
  #44
isaac085's Avatar
Ok if you see the picture they have 2 different options for the evo
The mitsubishi big version said is for evo 5 speed and
The mitsubishi evolution version said is for evo 8-9 but for 6 speed so which one i need to order for my ralliart.
i hope somebody can help me, cuz am confused
Thanks
Old Aug 22, 2008 | 08:56 AM
  #45
isaac085's Avatar
