Lancershop.com Short-shifter kit
#31
question on the bushings install: The stock bushings are connected to the line pin /w a bolt, then the boot covers the pin. The bushings they provide done seem to attach to the pin anywhere. Unless thats what the C shapped washer-ish part does, but I dont see how. How did you guys get this in? I see the stock looking like this:
...................-|-- pin
....boot....----|---- brass washer
/\/\/\/\/....==|== rubber 'washer'
---------|=|__|__| bushing
. . . . . . nut
anyone? (sorry, my ascii skills are teh sux. ignore the .'s, the DB filters excess whitespace)
thanks!
. . . . . . nut
thanks!
#32
I'm kinda confused (such as, where are you seeing a bolt??), but I'll do my best to explain.
Actually, nevermind. Check out the how-to section and there's a write-up, with pictures, on just how these bushings go in. All will become clear. If you're still having problems, post and I'll try to be of more help.
#34
i was talking about the line bushings, not shifter bushings. ANyway, I got them both in. I didnt relized that the bushing was in the brass ring =) The fact that I did it at night /w little light didnt help. ANywy, just took it for a test, minus the short shifter. The bushings made shifting a lot more crisp, although it seems to have more resitance. I'll grease everything up when I put the short shifter in. that should take care of it.
#36
the bushing slips in place of the old one.....the large "C-clip" goes on the bottom of the bushing when you have it in place....then you use the cotter pin on the top to hold it in place
#37
I've gotta give my props to the lancershop short shifter kit. I love this new shifter. I never thought that an inch or two could make that much of a difference, but it does. Only thing, I'm waiting for is the shifter bushings. I installed the under hood ones though. I wish the shifter came with a counter weight already on it like our stock shifter has. The shifting takes a little more effort but the counter weight knob makes up for it. The stock knob works fine but it feels a hell of a lot better with the included counter weight knob. I'm not really feeling that shiny knob, but I have a feeling it will grow on me.
