Ralliart Red Valve Cover
Old Sep 17, 2004 | 05:18 PM
thundrgryRA's Avatar
cool thanks..i am going to try that this weekend
Old Sep 17, 2004 | 06:32 PM
sicc22's Avatar
how did you prep the surface?
Old Sep 18, 2004 | 08:27 PM
ModernRacer's Avatar
just a lite sanding with 600 grit wet sand paper, dry it good and clean it with a mild solvent to remove grease and dirt then paint.
Old Sep 20, 2004 | 10:30 AM
Daddymac's Avatar
Modernracer - Do you still have off the heat shield?? I haven't had a chance to look at the bolt patern for sheild yet. Is it a seperate set of bolt to take that off or is it the same set of bolts that holds the header on??
Old Sep 20, 2004 | 12:51 PM
Just the bolts you see on the shield have to come off are the only ones
Yme
19
Jan 13, 2015 03:16 AM
Scottr126
31
Dec 29, 2013 07:05 PM
joedr
Jan 17, 2010 04:37 PM
cpunlamd
Jan 12, 2010 12:48 PM
Lumpy
20
Dec 18, 2007 02:19 PM
