check engine light is on
Old Sep 12, 2004 | 06:10 PM
coote's Avatar
ok, so i tried teaching my fiance how to drive a stick shift tonight. she finally got the hang of starting and stopping and shifting into 2nd. when she tried to go in reverse all she did was stall. she must have done that 6 or 7 times. after the last time my check engine light came on. anyone know what might cause this? does it have anything to with stalling that many times?
thanks
Old Sep 12, 2004 | 06:15 PM
no1v2's Avatar
I'm no expert, but when I put 1 and 1 together I'd say so! I can't believe you let someone (fiance or no) learn to drive stick on a nice new car
Hopefully someone here can help ya out...if not then you may have to get your Ralliart towed to a dealer.
captain150's Avatar
It could have to do with the stalling. Just take it to autozone and get them to read the code(s). Probably something to do with the stalling.
Old Sep 12, 2004 | 06:16 PM
Keyser Soze's Avatar
I second this statement. cant beat autozone and their free code checks
Old Sep 12, 2004 | 06:23 PM
coote's Avatar
thanks for the replys. i was thinking that's what it was. i have a friend that works in the service department at the mitsu dealer here, so i'll take it there tomorrow after work. thanks again.
Old Sep 12, 2004 | 06:48 PM
MitsuRalliArt's Avatar
I can't belive how complicated people make driving a stick for themselves. "Give gas, let clutch out slowly, push clutch in before changing gears."
I'm not baggin on the wife, I've just seen too many people with the mindset that it can't be done.
Old Sep 12, 2004 | 06:51 PM
blk-majik's Avatar
could also just take the battery terminal off. the ECL will go away. if it doesnt come back, problem solved! else, you have some work to do
Old Sep 12, 2004 | 06:55 PM
captain150's Avatar
The battery trick doesn't work with 1996 and newer cars. The codes are stored in the memory and removing the battery won't erase them.
Old Sep 13, 2004 | 04:29 PM
coote's Avatar
it's all good now. after i cranked the car for the 4th time today, it went off. everyone i talked to said not to worry then, so i'm not. thanks for the replys.
Old Sep 13, 2004 | 05:11 PM
captain150's Avatar
Yeah, if it went off on its own, don't worry about. Whatever test failed before (and caused the light to go on) must have passed so the light went out. If it happens again, the light will just turn on again
