motor mount hack job?
Old Sep 22, 2004 | 08:24 PM
blk-majik's Avatar
Has anyone tried to stiffen up the motor mounts /wout replacing them? I know some people /w OZ's that filled the mounts with a urithane-based glue to dampen the shock caused during acceleration. This helps keep the weight on the front wheels, and thus give better traction and faster launches. Are our mounts similar to the OZ/ES? Its dark, or i would just go look myself. Anyone know if you can get the mounts out (one at a time) without jacking or lifting the engine?
Old Sep 22, 2004 | 08:26 PM
blk-majik's Avatar
ohh yea, also does anyone know what the torque settings for the mount bolts are?
Old Sep 23, 2004 | 07:04 PM
blk-majik's Avatar
bump?
Old Sep 23, 2004 | 10:51 PM
blk-majik's Avatar
well, doesnt seem to be much interest in this, but I did found this article by ROCK. its for the OZ's and its pretty old, but should still apply to us:
https://www.evolutionm.net/features/...vomfeatures/14
I found some 3m windo-weld today for like $2.50, so once I get a chance to get to the mounts, I'll give it a shot.
W00T! POST #300!
Old Sep 23, 2004 | 10:53 PM
lookslikeanevo's Avatar
majik...why not shoot rob a pm...that would prolly be the best thing to do
Old Sep 23, 2004 | 11:15 PM
blk-majik's Avatar
just seems wrong, figuring he is SELLING filled motor mounts. but he wants over $200 for them. For whats its worth with my nearly-stock car, this is a better solution for now, until im well over 200 whp.
Old Sep 23, 2004 | 11:28 PM
pgmike's Avatar
deyeme sells motor mounts for cheaper, check them out and see if they have them for the RA yet.
Old Sep 23, 2004 | 11:30 PM
rob is usually helpfull even though he sells the stuff doesnt mean that hes not gonna aswer your question...unless you ask boe which is also a pretty safe bet
Old Sep 23, 2004 | 11:32 PM
blk-majik's Avatar
cool, will do in the morn. once I get it done, I can try to make a quick HOWTO to populate our nearly-empty howto section
Old Sep 24, 2004 | 08:09 AM
PDXRalliArt's Avatar
I saw a how-to on that a while back. I was going to do the same thing, I'm just lacking the time...
Old Sep 25, 2004 | 05:09 PM
Myszkewicz's Avatar
3M Windo-Weld was a popular solution for filling the motor mounts on a DSM. I did mine, because the rubber had fallen apart from age. I would do the same with my RA.
You can probably do them one at a time, if you support the engine with a jack and a piece of wood. Only problem is, you have to let the stuff cure for a while (I let it go for a whole day) before putting them back in and putting weight on them.
You could probably get a new set, fill 'em, swap 'em out with your originals, fill the originals, and sell those for what you paid for the new set.
Old Feb 8, 2005 | 11:35 AM
DM Racing's Avatar
The front mount for the standard Lancer and Ralli Art are pretty much the same. They're a slightly different shell shape (one is two pieces welded together, the other is one stamped piece), but they both bolt up exactly the same. Any front mount made for the std. Lancer 2.0 will also fit the 2.4. The rear mount is exactly the same from one to the other.
Old Feb 8, 2005 | 11:43 AM
bahamut's Avatar
At autozone, the window weld cost me over 7 bucks a tube.
You do need to cure them. Luckily for me, when my DSM was down, I was able to cure them for a week. It's pretty solid, consider the t-belt engine mount was split in two from age and stress.
http://www.raktron.com/misc/mt.htm
Old Feb 8, 2005 | 12:19 PM
tuffguy's Avatar
Curing them means just letting them sit and dry right? Do we need to put it in the oven ?
Also, the mounts on the RA are different than those on the ES/LS/OZ right? I ask because http://www.deyemeracing.com/products.asp...
EDIT: nm, I'm a retard:
