timing belt diy?
theres actually 2 tools as otter explained to me...(one of wich we used)
one is some kind of threaded rod to move over the timing belt tensioner pulley to get to the balance shaft belt(used only if you're not taking the tensioner off, wich we replaced anyway so we didnt need the tool)
as far as im aware its basically a long bolt...havent seen it so i can't confirm..
and the other one is this little square thing with two pins and a 3/8 drive hole on it(used to hold the pulley on straight while tightening it on to the tensioner bracket...wich ud be moving over w/ the rod if ur not taking it off and replacing the pulley and/or tensioner like we did)http://www.sears.com/shc/s/p_10153_1...24-114751638-2
^heres a link to what it looks like...(i honestly dont know if thats the same tool but it looks identical to it..)
Evo47
Nov 8, 2016 02:28 PM
MJ23FE
Jan 25, 2010 05:10 PM
Hcaruso4
29
Sep 26, 2007 04:23 AM
