Getting timing belt changed, do i need to replace tensioner as well?
Old Nov 5, 2016 | 10:51 AM
Evo47's Avatar
About to do the timing belt service, got a timing belt, water pump, timing and balance shaft belt and some pulleys. I'm just wondering, should I change the timing belt tensioner as well or can I reuse the old one? thanks in advance.
Old Nov 5, 2016 | 11:32 AM
Tuxevo's Avatar
It's wise to replace the tensioner if your replacing the belt. Especially if you're performing the 60k service. It's always good to be thorough when you're dealing with the pieces that keep your engine from smashing into itself.
Old Nov 5, 2016 | 11:53 AM
asu11's Avatar
Change it.
Old Nov 5, 2016 | 12:40 PM
Bhsj13's Avatar
just do it while they are in there.
Old Nov 5, 2016 | 12:43 PM
Evo47's Avatar
Originally Posted by asu11
Change it.
Alright I'll get it done. Thanks for your input fellas!
Old Nov 6, 2016 | 01:51 PM
4b11slayer's Avatar
Depends on mileage. 60k id re use.
Over 90k id replace hydraulic tensioner,tensioner eccentric, idler pulley.
Old Nov 7, 2016 | 10:43 AM
[TK]'s Avatar
replace everything. it would suck to have to go back in there again
Old Nov 8, 2016 | 02:21 PM
astral's Avatar
Absolutely replace the tensioner. It is my opinion that it is always wise to replace cheap parts that are only accessed through deep labor, when you are already there.
Old Nov 8, 2016 | 02:28 PM
Biggiesacks's Avatar
I didn't change mine at 60k and it blew up before I hit 120k and i had to rebuild the head. Replace it
SLVRNBLK
Mar 21, 2016 05:51 PM
Blue91lx
May 16, 2012 08:35 AM
Robertv34
Aug 27, 2011 12:55 PM
Beardly P
Jun 29, 2010 11:20 PM
nightwalker
Mar 11, 2007 08:24 PM
