Install headers n downpipe
Old Sep 6, 2012 | 05:20 AM
04mralliart's Avatar
Im going to install obx headers n down pipe on my o4 ra this friday I was wondering what I torque the bolts that connect the headers to the motor or if I just tighten it until I cant anymore.. I took a peek under my car and it looks like ill have problems getting the bolts off where the cat exists
Old Sep 6, 2012 | 06:22 AM
armeddoc's Avatar
Don't "tighten until you can't any more". I don't know the specific torque rating for that car, but it would be in the mechanic's manual.
Old Sep 6, 2012 | 07:06 AM
CrAnSwIcK's Avatar
to the head it 36 +/- 3 ft-lb i never torque them to spec though...
Old Sep 6, 2012 | 07:52 AM
Thanks
im just about to start taking off my old headers n i was wondering do i need to keep the old shiiitiy rusted out heat sheilds n reinstall them over my new ones. also i was wondering if i needed to put back on the header cover. any other info u wanna throw my way would be much appericated
also do i need to disconnect my negaitve on my battery and how do i go about resetting my ecu
Old Sep 8, 2012 | 05:27 PM
lanzerralliart's Avatar
EvoM Super Moderator
You won't be able to install the oem heat shield with aftermarket headers. There are no points to mount it to ,only on the OEM header.
Disconnecting the battery for 10 minutes will reset the ecu. Doing it will only help , just besure to let her idle for a 10 minutes after reconnecting. So the ecu can relearn with the next exhaust.
Old Sep 8, 2012 | 07:39 PM
keithislegit's Avatar
I heard that the OBX headers and downpipe make the car raspy. Is it true?
Old Sep 8, 2012 | 09:14 PM
i dont know my header is off n my dp is hanging the 2 bolts that connect after the cat are either so rusted and stripped er welded on. im kinda ****ed here what do i do . do i cut the pipe after the cat before the flange er am i going to have to cut it off after the flange before the second 02 sensor please help i need my car running before monday. thanks again guys for input n everything.
Old Sep 8, 2012 | 09:23 PM
anyone
er do i cut the blots some way i already tried.....pb blaster almost whole can every socket open end cresant vise grip n everythign tried torchin the **** outtta it nothing no budge i think its welded but theres so much rust.
Old Sep 9, 2012 | 08:07 AM
CrAnSwIcK's Avatar
heat and an impact should do it...if you're using a plumbing torch you need to heat it for a longer, if you're using like an acetylene torch or somthing you can melt the bolt heads right off...lol
Old Sep 9, 2012 | 08:55 AM
Arrow
it was a plumbin torch but i was holding the heat to it for a while. i just woke up. imma take a shower and run and pick up the acetylene torch. if that doesnt work. imma need to figure out something. is there a way i can uplaod pictures i can take a few with my phone so u can kinda see what im dealing with. thanks again guys.
Old Sep 9, 2012 | 09:45 AM
CrAnSwIcK's Avatar
you can attach images in the advanced reply, or you can create a photobucket account and embed the images...
Old Sep 9, 2012 | 10:31 AM
Install headers n downpipe-2012-09-08-22.13.53-2-.jpgClick image for larger version
Name:	2012-09-08 22.13.53(2).jpg
i hope thats how u do it. torch wasnt doing ****. i dont have an impact...i feel like shooting myself in the face
Old Sep 9, 2012 | 10:48 AM
two bolts holding me back everything else was a breeze... i got to this point in like an hour n ive been here for like 4 its bs. i wish i knew how to weld n the **** too do it id rig some some together.
Old Sep 9, 2012 | 11:08 AM
Raikiri's Avatar
that.... looks like a pain in the butt... you're probably better off hacking it off and welding in a new flange or something
Old Sep 9, 2012 | 11:17 AM
Holy **** that thing looks like it was from a shipwreck. You can thank the salty roads. I think cutting and welding is your only option.
