Engine wont crank after rebuild
Old Jul 7, 2014 | 06:26 PM
irving3d's Avatar
Hey guys, first time posting on here. Just thought i'd ask a couple questions and hopefully someone has the answers to them. Can anyone point me to some alternator or starter wiring diagrams. The reason is because i rebuilt the motor due to a spun bearing and had to take it out of the shop that i was using early and pretty much just slapped stuff on. After everything was plugged in the car doesnt even crank. Im wondering if i messed up the wiring to the starter.
Also My clutch has no pressure on it at all. could this be a reason for the car not turning over? maybe the clutch safety switch isn't engaging due to lack of pressure?
Any help would be greatly appreciated. If i cant get it fixed soon i will just have to sell it for parts or something because HOA will tow it if they see it has expired plates
Old Jul 7, 2014 | 07:18 PM
CrAnSwIcK's Avatar
the clutch interlock switch can be shorted with a fuse to eliminate that...its operation has nothing to do with pressure. does it make any noise at all (clicks, buzzing etc.)? if you have no clutch pressure, then you are unable to release the clutch, and the starter will not be able to turn the flywheel. have you tried starting in neutral? you need to bleed the clutch, and repair any leaks.
can you post a picture of how the starter is wired?
2010evoxgsr
Sep 4, 2017 09:04 PM
lancer586
Lancer Troubleshooting
Feb 21, 2017 09:37 AM
chdvg
Oct 18, 2016 10:42 AM
Night12000
Sep 28, 2015 08:03 AM
