D2 coilovers on ralliart
Old Mar 29, 2012, 09:43 AM
NicolaRalliart's Avatar
Hey guys im interested in buying d2 rs coils for my 05 RA, wanted to hear from anyone who is using or has used them before.... Do they lower the car alot cuz i read that they go to about 120 mm down
Old Mar 29, 2012, 10:37 AM
CrAnSwIcK's Avatar
120mm and you'll be leaving molten metal on the road...if you're going for "hellaflush" look, but you still want to drive on normal roads and streets, look into bags or hydraulics, or you'll be leaving bits of your car everywhere you go. Coilovers can give you a very low stance, but if you max out the drop, you'll run into problems, as you can't adjust the height on the fly...
Old Mar 29, 2012, 10:48 AM
No im not going to go down 120 mm i just wanted to know if those coils r good nd that i can lower as much as i want without any restrictions... Realistically im going for about a 3 inch drop
Old Mar 29, 2012, 04:25 PM
stockley1234's Avatar
3" is still incredibly low. I am at ~ 1.5" with my 195/60R15 winter tires on and have found myself scraping the front fender liners on some of the bigger bumps/dips and by just turning my wheel ~90%. I am not sure how it will be with my 205/50R16 summers but I am expecting the same because there is only .18" difference in diameter.
If you do go -3", expect to run a fair amount of negative camber all around
Old Mar 29, 2012, 04:30 PM
CrAnSwIcK's Avatar
big time camber, you'll be buying new tires every year...that's why i say it's not practical, and "hellaflush" is hella ghey...just my opinion...looks good for a show car, but for a DD or normal street driving, it's pretty retarded...
i'm on s-techs 1.5" down in the front, and i rub at full lock with stock sized wheels, and i've scraped my front lip on parking lot ramps, and i have a good 5-6" ground clearance up front...
mr2lover55
Jan 4, 2016 06:16 PM
RainesEVO
23
Sep 13, 2012 07:44 AM
RainesEVO
14
Jul 13, 2011 11:49 AM
johnnyli
Jun 29, 2009 07:44 PM
unclecomfort
Jul 29, 2008 08:34 AM
Quick Reply: D2 coilovers on ralliart
