lower control arm help!!!!
Soooooo does anyone know if the evo lower control arms will swap with ours or if the es or oz rally lcas are the same ones trying to get a new lower control arm but Mitsu wants 177$ for one. Also does anyone know if u can just replace the ball joint cause that's all I need really just trying to solve some very unessary wheel movement cause this ball joint is beyond shot please help.
EDIT: https://www.evolutionm.net/forums/04...placement.html
Page 2... found in literally the first thread I opened. Pay very close attention to the very last post aswell.......
i ended up getting a lca from orilleys today and only took me like 20 min to pull the old one and install the new one i it is much stiffer with a good ball joint in there. but as i feared it didn't fix the problem and my wheel bearing is 1000000000% bad lol worst sound i have ever heard come from the front of my car in my life. so got a new wheel bearing in hub ordered will have it tomorrow but now i need a knuckle because i know driving on a dry beat to hell bearing is just destroying the inside of the knuckle and i can't find one to save my life any help on that one guys?
i already know the knuckle has a grove ground in it already from the last time i pulled it apart to change the bearing but didn't think it would cause the bearing to go bad this fast so now I'm replacing it all.
and by the way just so everyone knows yes the 2009 ralliart and our ralliarts use the same steering knuckles with the press in bearing. and also the same wheel hub 5x114.3 lug pattern good info to know and the part number for the knuckle for our car is (mr491321). hope this will help some one else at some point.
My car has on a left front lower control arm from an ES. I did not install it, but the guy who did made no mention of having to do anything to make it fit.
Evo8RA
14
May 23, 2017 02:44 PM
JBN
Nov 26, 2016 05:39 PM
cullens089
Apr 4, 2016 01:09 PM
bbenavitz
Mar 29, 2009 12:32 PM
