BOV anyone?
Old Nov 17, 2008 | 06:17 AM
lancerdave86's Avatar
Bpv
did u use the stock evo IX BPV? u have any pics of the installation?
Old Nov 17, 2008 | 08:21 AM
excessiveboost's Avatar
yes it is the stock IX BPV I will take some pics and post them up when i get some time
Old Nov 17, 2008 | 10:24 AM
thanks that would be a big help
Old Nov 17, 2008 | 01:22 PM
heres my husbands myspace he has pics. the install was easy all you need is a screwdriver and about ten min.
http://viewmorepics.myspace.com/inde...lbumId=1058193
Old Nov 17, 2008 | 01:25 PM
I love the BPV
Old Nov 17, 2008 | 02:09 PM
Robevo RS's Avatar
if you guys want to buy a OEM IX or X BOV. Im 100% sure you can get a good deals on the Evo section. Just post it up you need one
Old Nov 18, 2008 | 06:37 AM
so any aftermarket evo IX BPV should work?
Old Nov 18, 2008 | 06:58 AM
GiLizILL's Avatar
im sorry im totally new to these mitsu's and turbo.
whats the diff. between BOV and BPV?
thanks
Old Nov 18, 2008 | 08:38 AM
as long as it not vent to atmosphere (VTA) mine is the OEM EVO IX BPV.
Old Nov 18, 2008 | 08:40 AM
thanks
Blow Off Valve BOV is vent to atmosphere which is bad because it cause the car to stall out and run ruff and By Pass Valve (BPV) blows the air back into the intake where it needs to go to work right.
Old Nov 18, 2008 | 10:30 AM
thanks a bunch excessive boost
Old Nov 18, 2008 | 10:47 AM
GiLizILL's Avatar
thanks for the info..so stay away from BOV's? and get the BPV instead?
Old Nov 18, 2008 | 11:44 AM
yes BOV's are bad for ralliarts
Old Nov 18, 2008 | 12:05 PM
ambystom01's Avatar
A BPV is basically just a BOV without the O (ie. the air is recirculated back into the intake stream).
Old Nov 18, 2008 | 03:10 PM
Robevo RS's Avatar
if you want to blow money you can get the APS dual vent BOV. which is under 30 psi proven the best BOV in the market.
