Forge Diverter Valve ordered
Old Jan 13, 2009 | 11:44 AM
  #31
scheides's Avatar
EvoM Moderator
Guys, do some research. The Forge valve sucked on the evo8's and 9's. Driveability was crap. Consider a stock evoX or IX valve instead.
Old Jan 13, 2009 | 12:42 PM
  #32
lancerdave86's Avatar
i didnt hear that but i didnt have one of the older evo's.
I just went with Forge because of there reputation and i know ppl that have them in there cars
Old Jan 18, 2009 | 04:40 PM
  #33
JONralli09's Avatar
lancerdave were you the one that posted the pics of the valve? and sound clips or vids yet?
Old Jan 20, 2009 | 04:35 AM
  #34
lookitznite's Avatar
oh god please lancerdave...this is something i need you must keep me posted about this... my friend just bought a stock evo9 bov and he said it will work with the RA..i'm waiting on his response as well but i really need some updates on this... also he said wont sound as good until intake was installed... anyone happen to have one installed yet...
Old Jan 20, 2009 | 04:55 AM
  #35
~BoOsTeR~'s Avatar
Forge DV driveability = ftl. MR valve driveability = ftw. Cone filter + pre maf = woosh.
Old Jan 20, 2009 | 04:57 AM
  #36
~BoOsTeR~'s Avatar
If the forge valve works with the standard recirc setup, then the evo 9 valve will work in the same manner. Just make sure you don't install it backwards. You'd be suprised how many people do just that.
Old Jan 20, 2009 | 04:58 AM
  #37
have to put the diverter valve back in then ill do it..... had to take it out cause i had to bring it to the dealer to turn off the oil light.
Didnt want the dealer to see it
Old Jan 20, 2009 | 08:24 AM
  #38
heavyD's Avatar
So you guys are getting new diverter valves for the cool sounds?
Old Jan 20, 2009 | 11:04 AM
  #39
98GSXtreme07's Avatar
Apparently... <<My conrtribution to this thread.
Old Jan 20, 2009 | 11:27 AM
  #40
heavyD's Avatar
I thought people were over the Fast & Furious. Bypass valves are put in place to protect the turbocharger bearings from compressor surge. Most aftermarket units perform poorly at this. The poppet style OEM bypass valves are far superior at preventing compressor surge. Unfortunately they don't sound as cool but people have different priorities I guess.
Old Jan 20, 2009 | 11:47 AM
  #41
i just went from a stock plastic bpv to an aluminum bpv nothing really changed except the sound and the fact i can swap out the springs when i reach higher boost
Old Jan 20, 2009 | 11:52 AM
  #42
ambystom01's Avatar
If the sound changed, something inside must have logically changed.
Old Jan 20, 2009 | 12:01 PM
  #43
bigger housing bigger blow off
Old Jan 20, 2009 | 12:04 PM
  #44
ambystom01's Avatar
How can a bigger housing have any affect? If you're just diverting air, the housing size should be irrelevant.
Old Jan 20, 2009 | 02:37 PM
  #45
HEXTALL27's Avatar
Can you hear a difference compared to the stock BPV with the stock intake installed??
