EV0 X rims
They would probably fit better if the offset was in the 45-48 range, 18x8.5 will fit with the proper offset.
I'd bet if you do any aggressive driving you'd chop those tires up real quick even at stock height.
The evo x wheels fit nicer than my rota's. Just alittle bit. +38mm to +35mm.
You really need +40 to +45 offset on this car to have it sit under the fender.
Yeah right to the 18x8.5's....You can have it at +35 offset and have it pass the rear fenders by 2cm and it'll still rub on the suspension and springs.
18x8.5 see here.
https://www.evolutionm.net/forums/la...will-work.html
and here
https://www.evolutionm.net/forums/la...heel-help.html
and here
https://www.evolutionm.net/forums/la...r-concave.html
