Boost Gauge Project
Old Apr 5, 2009 | 07:05 AM
08Lancer89's Avatar
Boost Gauge Project
Hey Guys.
I recently got a glow shift boost gauge from my friend along with the pod itself. The pod mounts on the dash i used velcro so I didnt have to glue it down or anything. The pod sat a lil too hight for my liking so I cut 1/2 inch of the bracket and drilled new holes so it sits as pictured below. Only down side here is that I have to drill a lil tiny hole in my dash, just big enough to get the vac line and 4 wires in. Iwas thinking of using a gromit to make it look clean. And if someone came out with something better later I will just plug the hole in the dash with on of those lil plastic pop clips. Anyways my question to you is do you like where its mounted? right or left? keep you guys posted on install.
Old Apr 5, 2009 | 08:18 AM
08Lancer89's Avatar
What u guys think?
Old Apr 5, 2009 | 08:57 AM
JONralli09's Avatar
not bad, i would of put it on the left side
Old Apr 5, 2009 | 09:06 AM
08Lancer89's Avatar
really why the left, its not on yet just stuck on with velcro
Old Apr 5, 2009 | 10:12 AM
elpoole's Avatar
Id use the pod system that CP-E is wokring on. It replaces the plastic above the spedo and tach for an OEM fit. It has three pods. Im going to put in boost, afr and oil or tran temp.
Things velcro'd on the dash just doesnt do it justice.
Old Apr 5, 2009 | 11:27 AM
Ralli_85's Avatar
Registered User
yeah, sorry dude.. Kinda dusty looking.. I recently got a megan boost gauge, it's frickin hot! Matches the stock speedo and tach, but I'm still waiting for either an A-pillar pod or the cp-e pod..
Old Apr 5, 2009 | 12:06 PM
08Lancer89's Avatar
sorry about the pic quality its from my phone. Im putting it on the left hand side. And trust me the thing dosent move an inch even when going 50 arounf a turn. Also the GAUGE is not even in it yet.....
Old Apr 5, 2009 | 01:07 PM
bossssman38's Avatar
i would say left also. Post pics when its set up please!!
Old Apr 5, 2009 | 01:46 PM
08Lancer89's Avatar
I took a picture of it on the left but cant post it till later cuz im at work.
Old Apr 5, 2009 | 03:12 PM
hibby's Avatar
OT, but ya gotta get that detector mounted higher up, my friend.
You can use a telephone cable and inline phone cord connector to lengthen the power adapter...mount it right under your mirror, run the wire across the headliner, down the a-pillar and across the bottom of the dash.
Higher mount = better detection.
Old Apr 5, 2009 | 05:16 PM
08Lancer89's Avatar
True, well see about that later. I am also thinking of runing the lines threw the air duct so I don't have to drill a hole in the dash at all.
Old Apr 5, 2009 | 05:47 PM
08Lancer89's Avatar
Old Apr 5, 2009 | 06:47 PM
RallyGoneEvo's Avatar
Does anyone have any pics of the CP-E pod? I'm interested in that...
Old Apr 5, 2009 | 08:20 PM
left for sure.
Old Apr 6, 2009 | 07:15 AM
08Lancer89's Avatar
yeah thinking of putting the wires threw the top lil vent, then putting the vac line threw the fire wall were I ran my power wire for my amp
