do evo gsr wheels fit on the 09 RA?
Old Apr 13, 2009 | 11:34 AM
xdmitrix's Avatar
anyone try this?
alternatively, is anyone familiar with the tirerack.com site? I tried using the vehicle selector, but it lists no wheels/tires for the RA, probably because it's a new car.... should I assume any wheels that fit the 09 GTS will also fit the RA?
Old Apr 13, 2009 | 11:44 AM
C H's Avatar
C H
GSR wheels don't fit, but anything that fits the GTS should work on the RA since they are the same body/suspension layout. The GSR has a wider track and wider bodywork to accomodate the larger rim/tires.
I have heard 225 are the widest you could go without any rubbing problems.
Old Apr 13, 2009 | 12:03 PM
Bom's Evo's Avatar
Yes, you can use the 08-09 GTS wheel fitments.
Stay in between +40 and +45 wheel offsets for a good fit inside your fender.
GSR wheels fit very snug on unfolled fenderes. The offsets are like +37 though. You might touch the fenders in the rear on HARD turns or with 5 people in the car.
Old Apr 13, 2009 | 12:05 PM
Bom's Evo's Avatar
I've heard the widest you can go on the Ralliart is...
245/40/17 tire
on a
17"x8.5" rim
I'm not sure on the offset, but I know the rear fenders need to be rolled!
Old Apr 13, 2009 | 02:41 PM
RallyGoneEvo's Avatar
Why go down in size? I like my 18's =]
Old Apr 13, 2009 | 02:52 PM
RobertRA's Avatar
yes the evo x wheels WILL fit!
Old Apr 13, 2009 | 03:09 PM
C H's Avatar
C H
Do they fit without rubbing?
Old Apr 13, 2009 | 10:43 PM
bye2u's Avatar
depends if you're going to lower the car or not.. stock height shouldnt have any issues but lowering will require some fender rolling..
Old Apr 13, 2009 | 10:57 PM
jRox's Avatar
^+1. Agreed.
Old Apr 14, 2009 | 07:03 AM
Bom's Evo's Avatar
You go down in size to fit a wider tire.
The weight of the wheel and tire also go down as well.
I also prefer the 18's, but if I were to race the RA. I would go to 17" TE's or something.
Old Apr 14, 2009 | 09:54 AM
xdemoulasx's Avatar
i wonder how 17" evo 9 BBS would look?
Old Apr 14, 2009 | 06:06 PM
evocowboy's Avatar
245/40/17 tire
on a
17"x8.5" rim
I confirmed this statement w/ my evo VIII enkies!
Old Apr 14, 2009 | 06:39 PM
craigb3's Avatar
pics? everyone keeps saying it works but no one posts proof.
Old Apr 15, 2009 | 01:11 PM
TheDriver11421's Avatar
they fit but poke out a bit. requires fender mod if u drop. there is a pic on here somewhere.
Old Apr 15, 2009 | 01:13 PM
scroll down
https://www.evolutionm.net/forums/la...els-gts-4.html
