Improving Handling...
Old May 2, 2009 | 06:58 PM
  #61
Smike's Avatar
Originally Posted by babiesdadies
What would be a good set of coilovers, sway bars and strut bars for Rally Cross for RA?
I plan to do alot of fun stuff at the track with the RA but its my daily driver also?
https://www.evolutionm.net/forums/ev...ally-cars.html
Old May 2, 2009 | 08:05 PM
  #62
C H's Avatar
C H
Originally Posted by Nightwish1094
Wow. I have a 98 M3, and i love my RA, but i find it handles nowhere near as well. The M3 is so balanced and steering is so much tighter. What color you got. 5speed?
Both cars are silver ext, black int.
Don't get me wrong, the M3 is great. The Pilot sport Primacy's I have aren't a great performace tire, but are good for everyday driving. They are good in the wet and quite but not for hard driving. I have only had the RA for 3 weeks, but I think that it is pretty close when driving on the street for grip (spirited but cautious driving, don't want to smoke a curb).
But just going by the specs the RA pulls .8g and 128 ft 60-0 braking while my 13 year old M can pull closer to .9g and 60-0 at 110 ft all day long. So at the track or auto X I know the M will be the winner.
I actually find the RA steering very tight, like a go cart. The M3 is probably more precise because of RWD and 50/50 weight dist you know what the car is doing and you can throttle steering it. The RA because of the AWD can't pull off the same sort of balancing act, at least that I have seen. I suspect the EVO X with AYC might have a chance to do that.
Old May 2, 2009 | 09:24 PM
  #63
Moofahsah's Avatar
Originally Posted by Moofahsah
for a DD, that i intend to hug corners with lol
i forgot to add that i will occasionally hit the mountains for the snow...i like the suggestions so far tho
Old May 3, 2009 | 01:36 PM
  #64
devinclfalcons's Avatar
Buy an Evo X MR
Old May 3, 2009 | 03:28 PM
  #65
babiesdadies's Avatar
Originally Posted by ambystom01
If you're serious about rallycross, you need a very different setup than someone who autocrosses or tracks.
What is the difference between rallycross and autocross?
Old May 3, 2009 | 03:33 PM
  #66
ambystom01's Avatar
Rallycross is on dirt, snow, ice, etc., autocross is on tarmac.
Old May 3, 2009 | 03:46 PM
  #67
I want to do auto cross what do I need for that?
Old May 3, 2009 | 03:50 PM
  #68
ambystom01's Avatar
You only need a car and a helmet. If you want to improve the stock car, sway bars, good tires and good brakes are a starting point.
Old May 3, 2009 | 04:05 PM
  #69
Thanks man your posts are very helpful.
Old May 3, 2009 | 04:10 PM
  #70
How does It work some one told me you go around cones and stuff like that and you aim for the best time is that how it works?
Old May 3, 2009 | 04:40 PM
  #71
Metall1ca's Avatar
basically, yes.
Old May 3, 2009 | 04:49 PM
  #72
Smike's Avatar
Bunch here:
http://www.youtube.com/user/smikeevo
Old May 3, 2009 | 11:20 PM
  #73
Moofahsah's Avatar
Originally Posted by devinclfalcons
Buy an Evo X MR
o really ... thats such a good suggestion on the forum for improving the handling of a 2009 ralliart...
Old May 12, 2009 | 02:17 PM
  #74
boozeup&riot's Avatar
It's been said a few times already but people keep gravitating back to suspension.
Upgrade your wheels/tires first. If you don't want to do the wheels, do yourself a huge favor and at least get new tires before you start even thinking about any of this other stuff. It's not simply that you need more sticky tires either, you need *wider* tires. Your suspension upgrades will be for naught if you do not increase the contact area between your car and the ground. Once you've picked up the wider tires, you can then start to analyze what kind of suspension setup lends itself best to your needs/driving style.
I realize that its not as glamorous as a nice set of coilovers or the look of a slammed RA/Evo, but you'll be most satisfied not rolling around on pizza cutters any longer. If you do decide to upgrade your wheels (recommended), go with something lighter and you'll find the benefits of the unsprung weight you just shed may outshine the benefits of lowering springs and an alignment. Just my .02. Good luck with your decision.
Old May 12, 2009 | 02:19 PM
  #75
ambystom01's Avatar
I'm of the general opinion that coilovers are quickly becoming a show mod rather than their intended use as a performance upgrade.
