is break-in necessary?
Old Jun 21, 2009 | 09:51 PM
dyck888's Avatar
hi, i got my new 09 ralliart for about two weeks now and it has 400miles in it. i sometimes used the sport mode in a freeway and pushed it up to 80mph. was it bad for my car? i am not sure if i really need to follow the break-in rules? please, i need some advice! thanks in advance!
Old Jun 21, 2009 | 09:57 PM
2LOFD3ATH's Avatar
No. Just don't ever run an engine that isnt fully at opperating temp (water, block,oil) hard.
Old Jun 21, 2009 | 10:02 PM
xi's Avatar
xi
It says vary your engine speed during the first 500 miles or something. Meaning don't drive it off the lot then keep it on cruise control at 65 for the next 3 hours.
I basically let the car warm up and drove it like I stole it for the first 500 miles. Didn't slam the gears in but basically redlined it gently (yes it sounds odd) a coupla times. Took it out to some windy backcountry roads, sport mode, and had my way with it. Took it up to 100+.
1300 miles now, no problems yet.
Old Jun 21, 2009 | 10:28 PM
2LOFD3ATH's Avatar
Yeah, your engines fine. street engines are basically designed with worse case scenario in mind, non synthetic oil, being changed at 10k miles, no warm up time before hard use, just the general abuse policy. Really don't worry about it, besides its the first 20 miles that seat the rings, if your worrying about a good seal at 400 its way way past to late.
Old Jun 21, 2009 | 10:54 PM
higgs's Avatar
just try not keep RPMS steady like already said ^^ i didn't follow any and drive it real hard 3k miles so far so good
Old Jun 22, 2009 | 04:58 AM
dboz's Avatar
Just drive and don't worry about it, that is what the warranty is for. Do you think they warm them up when they drive on and off the ships? Do you think the port guys have some fun? The engine gets broke in as far as the rings when they start the car to drive off the line. Unless you are there at the end of the line like they do with the Corvette, there is not really much you can do. Has anyone ever went for a test drive. I know I surely did not take it easy and the car had 5 miles on it.
Old Jun 22, 2009 | 08:31 AM
dyck888's Avatar
alright! thanks for all the info....
btw, does anyone experiencing the burned smell every time you stop running the engine?
Old Jun 22, 2009 | 09:05 AM
xdmitrix's Avatar
i noticed some chemical-ish smells from my RA the first 2-3000 miles.... i think it's everything getting worked in.
Old Jun 22, 2009 | 09:47 AM
xi's Avatar
xi
Probably the transmission + all of the protective coatings they put on everything. I love that smell...
Old Jun 22, 2009 | 09:51 AM
2003lancerevo8's Avatar
Everyone's opinion is different, you should vary the engine speed though... When I bought my evo8 I literally took it off the lot and started driving the living hell out of it. No joke, and my engine and car was completely fine!!! I wouldn't recommend doing that but my car was fine.
Old Jun 22, 2009 | 10:28 AM
xdmitrix's Avatar
i imagine they do some break in of the engine at the factory.....i'm sure those crazy precise japanese people made sure of it.
Old Jun 23, 2009 | 03:16 PM
madcows's Avatar
+1
We've had this discussion in this forum several months back.. A quick search should revel it with sources citing the same this Eric said.
