Aftermarket Ralliart...
I can't seem to find any aftermarket body kits or peices around for the 09 ralliart. I can really only find pieces for the Ralliart that make it look like an Evo lol. Is that innacurate? Can you guys find any?
Look up Lancer body kits, the kits, for the most part should fit the base Lancers.
08-09, everything should be exactly the same. Only problems would be clearance issues with the intercooler and exhaust, but these shouldn't more than a minor issue. The dimensions, mounting, etc are the same with the base-Lancers, but not the Evo.
Are you saying I can't get a kit made for the evo? Or that if I have an Evo I can't use a normal kit?
He is saying:
you CANT get a kit that is made for the evo X..
but you CAN fit a kit that is made for the 08-09 base lancers (Not Evo X though..) but you might need to modify the front bar to accommodate for the RA's front mount and also modify the rear bar to fit the RA exhaust outlets as they are different to the base lancers exhaust positioning..
He is saying:
body-kit.com has them for all the lancer types (ES,GTS, Ralliart, And Evo)
Here are the links:
http://body-kit.com/model_mit_lancer08bodykits.html
http://body-kit.com/evolution_x_evox_body_kits.html
Here are the links:
