Tpms ?
Old Jul 17, 2009 | 08:31 PM
akj237's Avatar
Tpms ?
I'm looking at getting another set of wheels for my Ralliart. That way I can use the stock wheels for winter and the new wheels for summer. With the new wheels I was looking at getting new TPMS sensors with them from Tire Rack. With new TPMS sensors what do you have to do to get the system to recognize them? I looked in the Evo X forum but that thread seems to just go in circles with no answer besides go back to the dealer which I don't trust them to even change my oil.
Old Jul 17, 2009 | 09:19 PM
tjac357's Avatar
i can't give you an exact answer but i hope this helps some. i did the same and the tire store i bought the tires from took the factory (TPMS) out of the advans (they're in the air valve) and put them on my new kuhmo's. I have the kuhmo's on enkei's now and this winter will get pirelli sotozero's and put them on the stock rims. I'd advise going to a tire specialty store or your dealer and talk to them.
Old Jul 17, 2009 | 09:40 PM
C2Rally's Avatar
I have run circles around this myself last year when I changed wheels. the only way seems to be the dealer. Apparently they have a specific procedure for sensor calibration that is only Mitsu possible. I eventually had to cough up the dough for the oem sensors to get it to work right after trying to go through a wheel specialty dealer for other sensors.
good luck otherwise!
Old Jul 26, 2009 | 05:37 PM
akj237's Avatar
Well it sounds about as fun as I thought it was going to be. Thanks for the info.
Old Jul 26, 2009 | 06:29 PM
Robevo RS's Avatar
or you spend extra and you buy for your own set of toolS
http://www.bartecusa.com/tpms_end_user_tools.htm
Old Jul 26, 2009 | 10:40 PM
Ladogaboy's Avatar
You shouldn't have to recalibrate the TPS when you rotate the tires, right?
Old Jul 27, 2009 | 06:34 AM
jazket's Avatar
You need to get your new sensors from Tire Rack, they will balance the tires and send it all ready to you (assuming you're getting wheels + Tires + Sensors + Bolts);
Then you have to take your car to the dealer and have them re-calibrate the system. It's 90+ bucks depending of the dealer I guess; If you take your wheels out and put your stocks back in winter you will then again get the "Service Required" TPMS message on your display.
Hope that helps
Old Jul 27, 2009 | 07:57 AM
havock28's Avatar
so every time you swap out tires and rims.. summer to winter.. winter to summer.. you have to go to the stealership and pay $90????
Old Jul 27, 2009 | 08:48 AM
jazket's Avatar
That's the problem.... whenever you swap wheels/tires you'll get that tpms message so it doesn't really make sense going through that, unless you don't care bout leaving the message annoy you for 2-3 months (for as long as winter stays around) or paying the re-calibration every winter
I'm trying to figure out if how to do this myself also cause I've paid 94 bucks TWICE!!! for me and my wife's ES since I installed my stock on her car;
Sucks!
Old Jul 27, 2009 | 09:51 AM
evil03's Avatar
yup i just confirmed with mitsu.. the RA and all Mitsu cars... only registers one set of sensors... not like other cars out there... and they told me its a Smart TPMS system... and some other stuff.. but i blanked out when he said i need to get it reprogrammed if i get new sensors... and its like 30mins shop rate.. with is like 50 bucks... thats some BS.... we need to give them some hell and make it FREE.... or 5 bucks a sensor....
Old Jul 27, 2009 | 06:26 PM
akj237's Avatar
Yup, sounds like a pain in the ***. I guess I'll either have to make some phone calls to local shops and see if they have the TPMS tool to program new sensors or buy the tool myself. I'll be damned if I'm paying the dealer $180 a year for something they'd probably screw up anyway. I don't think that Bartec Trackside tool will work to put the ECU in learn mode to recognize new sensors from what I read. Won't know I guess until Bartec returns my email.
Old Jul 27, 2009 | 06:33 PM
revvin9k's Avatar
It takes literally two minutes. If you guys were local I would do it for free.
Old Jul 27, 2009 | 08:19 PM
akj237's Avatar
....what tool are you using? Any insight on what you are using and the procedure would be great
Old Jul 28, 2009 | 10:07 AM
aestival's Avatar
Hope that helps
I just get my dealer to swap the wheels; they seemed to do the re-calibration for free, though it's probably hidden in the labour charge. It wasn't unreasonably expensive compared to other shops where I've had wheels swapped (with no TPMS), but it isn't as cheap as doing it yourself, of course.
I can see how the TPMS calibration is a real pain for the do-it-yourself mechanic crowd, but if you're so set on that, then just pull the TPMS from each existing wheel and mount them on the corresponding new wheels. Problem solved -- provided you have the proper equipment to put tires on wheels, of course.
Old Jul 28, 2009 | 10:58 AM
revvin9k's Avatar
Even if you keep the sensors in the same locations, there are chances that it will still trigger the light. It's kinda hit or miss with these systems.
Hondas system automatically re learns the positions on their own.
We use the Bartec Wheelrite Tech 400 plus here at the shop. It plugs into your diagnostic port and it does all the work in under a minute or so.
