keeping can of fix a flat vs. spare tire
Is it plausible to just keep a can of fix a flat in my trunk vs. the spare tire to save on weight? will it junk up the tpms?
Unless you are racing your car I do not think the weight savings of no spare tire is really worth it, and if you do go to the track you can just take it out temporarily.
Otherwise just do not have a spare and hope you are in cell range to call someone if your tire goes flat. =)
-Taranis
If the spare affected the LSD that badly, Mitsubishi would not have included it with the car. Just follow the instructions and don't drive the the spare for extended periods of time.
Also, when I had a flat, the entire sidewall blew out. Fix a Flat wouldn't have helped.
fix a flat doesn't necessarily ruin tires. My dad worked in a tire repair shop for 10+ years....while he told me it sucks ****, it's not a death sentence for every tire.
That said -- i wouldn't depend on it. Man up, keep the spare. I've had 2 massive blowouts on the interstate that fix-a-flat wouldn't even touch.
Is fix a flat available for an 18" tire? I've looked in stores just out of curiosity ans waiting for the fiancee and only found cans that say up to 16" tire. I've also heard that they make an absolute mess out of the inside of the tire when used and a PITA to clean out when the tire gets repaired.
I carry an $8 plug kit which you can get from any auto parts store and a small air pump which is equally cheap. I have a Corvette and it comes with a kit of slime and a pump. The idea is the same. Instead of slime I bought a plug kit. Plug the hole and refill the air. You can find pumps cheap. Never worry about flats and you don't have to carry a spare.
Dog
Dog
is slime generally better than fix a flat? i was browsing online and there's sealant stuff you can buy that's designed for fixing bullet holes in large hummer tires.
i looked at those plug kits, but the idea of fixing a hole at night with one of these kits seems a little far fetched.
As far as I know, all that stuff is the same except for the brand name on it. It's not intended to be any sort of permanent or semi-permanent fix...only supposed to get you down the road to the garage.
I used it a couple years ago to make it home late at night, and the wheel was sitting back on the rim again in the morning. This stuff will work in an emergency, but you'll cause yourself less headaches if you just keep your donut in the trunk.
twistyking
Dec 15, 2009 08:34 AM
EvilTechnology
Oct 15, 2007 08:18 AM
