Help warning lights!
Old Jan 19, 2010 | 05:26 PM
tjac357's Avatar
Originally Posted by 08Lancer89
Yeah the asc went off by itself and I can't put it back on.
That's exactly what happened to me when mine went out. Mine was off and when i went to turn it back on it was as if the ASC was permanently off. Might wanna get it looked at.
Old Jan 19, 2010 | 06:37 PM
08Lancer89's Avatar
What did u do to fix it?
Old Jan 19, 2010 | 07:24 PM
03chi-town0Z's Avatar
light 1: tpms, obviously since sensor is off
light 2: acd service required/malfunction probably because of different rotation speeds and such...see light 3
light 3: traction control warning/loss of traction due to lower radius on spare rotating more than normal rim
Old Jan 19, 2010 | 07:32 PM
08Lancer89's Avatar
U guys pretty sure that's all that's wrong.
Old Jan 19, 2010 | 08:02 PM
tre's Avatar
tre
well it makes sense. as well its your cheapest solution since your already getting a new wheel and tire.
Old Jan 19, 2010 | 08:08 PM
08Lancer89's Avatar
I bought all new rims it was time to upgrade anyways and my tires are getting bad. What changes do u guys think that It would be more than what we assume. I'm praying that's all that's wrong.
Old Jan 19, 2010 | 08:11 PM
tre's Avatar
tre
I'd cross that hurdle if the time comes.
got any friends with ralliarts? have them throw their spare on and see what happens.
Old Jan 19, 2010 | 08:12 PM
08Lancer89's Avatar
One of them could be your sensor cluster. They'll have to scan to ind out. Mine went out doing donuts and my tech said they're very delicate and from your crash I wouldn't be surprised if yours went out.
What sensor cluster?
Old Jan 19, 2010 | 08:13 PM
08Lancer89's Avatar
I'm the only ra here in my part of town sadly I'm all lonely. Any of you guys wanna try it for me.
Old Jan 19, 2010 | 08:16 PM
silthos's Avatar
I had the same this happen to my ralliart about a week ago. The wife hit a pot hole and blew the tire. Once they mounted on the new tire, all the lights went away.
Old Jan 19, 2010 | 08:28 PM
08Lancer89's Avatar
She had the center diff light also? That's the only light that scares me the most.
Old Jan 19, 2010 | 08:34 PM
silthos's Avatar
She had that light also. I had it come on before that. A vac line came loose.
Old Jan 19, 2010 | 08:36 PM
08Lancer89's Avatar
Hummm strange hopefully all will clear as soon as my new rotas come. Can't wait . I will be VERY HAPPY if they all go away.
Old Jan 19, 2010 | 08:38 PM
silthos's Avatar
lol. I know the feeling!!!
Old Jan 19, 2010 | 09:30 PM
tjac357's Avatar
the sensors that send info to the AWC system. I got mine fixed under warranty. I could find out how much they were without a warranty if you wanted. Just wanted to give you a heads up, since they're apparently very delicate.
