09 Ralliart Stage 2 Tune
Old Apr 15, 2010 | 02:45 PM
Splatzjackson's Avatar
I am having my 09 RA tuned to a stage 2 in the next couple weeks (waiting on parts to arrive) and I wanted to find out if anyone out there has upgraded their RA to a stage 2 tune with only a drop in high-flow intake filter and turb-back exhaust. If so, what were your Dyno readings? I have seen one similar tune from Cobb at 262hp and 310 ft/lb.
http://plano.cobbtuning.com/dyno/index.php
Old Apr 15, 2010 | 03:07 PM
athmak15's Avatar
The car with 262/310 is Runaround. He has a HKS drop in filter, high flow cat, downpipe and a catback.
I haven't seen any other dyno readings with Cobb Stg 2 since the stage 2 maps came out less than a week ago.
Old Apr 15, 2010 | 11:48 PM
dukeds's Avatar
what would happen if i use the stage 2 map without having at least a high-flow cat. ?
Old Apr 16, 2010 | 09:40 AM
Runaround's Avatar
I actually have a K&N filter, but the rest of that list is right. I believe that running the COBB stage 2 tune without having a high flow cat could be dangerous. They are expecting a certain amount of air flow on the tune, and the standard cat would be much more restrictive. I would hold off till you get a high flow cat before doing the stage 2. If you haven't put on any of the exhaust yet, I would wait till you have the high flow cat and they can just do it all at once. Makes it easier to install it that way, and then you aren't paying for it twice.
Old Apr 16, 2010 | 10:10 AM
I agree with Runaround. Wait until you at least upgrade your exhaust (turbo-back). The tune is designed to work with a certain flow of air through your engine/exhaust. Upgrading the exhaust and having it tuned at the same time will save you money in the long run.
razorlab
548
Sep 14, 2019 07:23 AM
SOG RA
34
Sep 17, 2015 09:14 PM
Crackerjam
Sep 15, 2015 03:12 PM
drexelmech
Northeast Region
Mar 25, 2012 05:32 AM
jonhix09RA
Sep 13, 2010 09:54 PM
