RA Led mirror covers
http://www.roadracemotorsports.com/s...00c6c31acf32bf
i have a few questions....
has anyone seen these?
does anyone know the quality of RRM?
and i like this concept is there any other companies that offer these?
I bought a set of those from another site x-factor design but I am having some issues. I've connected everything up correctly i believe but this has triggered ACD service light on dashboard. I will undo and redo all wirings on the weekend to see if problem persists. When I unplug the mirrors wire which require a constant 12v from the power source, the ACD error goes off
Connected as per instruction manual except for a wire which requires to be connected to the constant 12 volt white wire using a splice (tried with the splice, did not work, so I simply connected the wire into touch with the 12 volt wire in socket c-307 behind the glove box. Hopes that makes sense. Could this be what is actually causing this error?
RAswish if you would like... I bought a set that is very similar to the RRM ones. I got it on e-bay. They are brand new (x42 color tho...)
PM if you are interested in taking them off my hands. I'll give you a good deal on them.
Thanks for the suggestion of what may be the problem there
once i find out a little more info on them and how simple/difficult the install is, i will let you know
