intake?
Old Sep 22, 2010 | 09:21 PM
Forever_A_Fan's Avatar
intake?
just bought an RA a couple of weeks ago, any suggestions on an intake? the ams one requires tuning, so im looking for something i can just throw on and not worry about that.
Old Sep 22, 2010 | 09:25 PM
S2K2EVO's Avatar
You won't find one all require a tune.
Old Sep 22, 2010 | 09:58 PM
Gman4ver's Avatar
Drop in filter, Hks, works, k&n. It wont rally give you preformace gains but def worth it till you get a tune.
Old Sep 23, 2010 | 06:40 AM
zx-319's Avatar
If you look in the How to section there are instruction about how to build your own short ram intake using a K&N air filter and an Evo X MAF housing. This will cost you less than 100$ and allow you to hear the turbo sucking the air and the BPV.
But from I've read, you'll get more gain from a drop-in filter.
And you should not worry about leaning out you AFR with this setup. I did it on my car, and in WOT my AFR is well below 11 (even when using GST Basemap which leans the mixture a little bit).
I think all the other aftermarket intake kits replace you MAF housing by something larger or include a bypass that falsify the MAF readings, so those would definitely require a tune if you want to ensure you engine will last.
